Results 1 to 15 of 15
Thread: help with 40" project
    Default help with 40" project
    to start out, plain and simple. i know NOTHING about electric boats. i currently have a 60" gasoline powered deep vee. looking for a new project i thre nitro out because of the price of gas so i looked over to electric. moving on to the project.
    i have a spare 40" prather hull, its quite heavy but a reasonable wieght. i have been looking around the forum and youtube for setups on this size boat but to be blunt, everyone is running the supervee's. i've been considering a Feigao 8xl or 9xl motor. i'm not building this boat for competition and not looking for speeds over 40mph. i want this boat to have something to toy around with while my big boat is cooling off, and for a change of pace. any suggestions on motor, esc, and battery combos i should use?
    1,711
    KB45 11XL on 6S lipo or 18 NiMH, X645 prop, 120 amp controller.
    Over 20,000 rpm at 70 amps. Mid 30's.
    Water cool everything.
    ReddyWatts fleet photo
    Apr 2008
    155
    Is there drive hardware ??? Is there any way you would do dual motors, for a change of pace ???
    1,711
    Dual motors/props would be ok in a cat hull.
    Apr 2008
    155
    Unless you choose dual outdrives
    Mmmmmmmm Outdrives
    1,711
    Start a build thread and GO for it!
    Jan 2008
    216
    Its a Deep Vee , I don't remember Prather ever making a cat hull.I ran a big ( maybe 48" )Prather hull with 2 Rossi 65s , It was fun .
    1,711
    My suggestion to "Cheezewizz69", with the a large prather hull is:
    My suggestion to "blastoff" is go for a dual outdrive, if he wants to be creative.
    Apr 2008
    155
    Duals Rule (just my opinion) Here are two of my Dual's
    Cheers
    when i bought the hull it was set up for nitro and already has a shaft for the flex cable molded into the hole, i was hoping i could just utilize it and not have to start cutting it up. so i dont think i'll be doing dual just yet also, remember this is my first electric build, EVER, so i dont want to get complicated with anything.
    and between lipo and NiMH, which will give me a longer run time.
    1,711
    You compare the "mah" rating of the battery. This is what determines the runtime. It is the same for a NiMH or lipo.
    To calculate run times
    Battery Mah rating (times) 0.06 (divided by) motor load in amps = run time
    Example: 5000 MAH (X) .06 (divided by) 70 amps = 4.25 minutes of run time (times) 80% = 3.4 minutes
    Should not run your batteries down more than 80%.
    Jun 2007
    wi
    242
    blast off twins do rule!
    the one with twins is the big boat
    cheeze!! i love those old prather hulls so do her justice, the remind me of old scarab ninjas
    Apr 2008
    155
    I think that's why we stare at females with low cut tops !!!!
    i am NOT doing twins
    Jun 2007
    5,190
    Quote Originally Posted by skidooguymxz550 View Post
    Skidooguy, what motors, batteries, esc's are you going to run and what is the length and bare weight of that hull. I would personally run a single powerscheme on a V hull. Cheesewizz69 follow ReddyWatts suggestions
    Douggie
