Results 1 to 2 of 2
Thread: Proboat Formula FasTech first run
    Default Proboat Formula FasTech first run
    first run - batteries at about 1/2 charge.
    My pond had a ton of pine needles floating on the surface so this was clogging up my turn fins about every other lap... so this is just a quickie but man the boat is quick out of the box -
    http://www.youtube.com/watch?v=nr8UILFNe5M
    side note-
    this is the 2nd Fastech I've gotten. The first had a bad radio in it - and so did this one. I like JRs XS3 Pro system and use it with most of my rcs so I had an RS310 I put in the Fastech. Still have some tweaking to do with the end points.
    My pond generally has some pine needle debris on it - can anyone suggest a better hull for these conditions?
    May 2009
    3,180
    ...get LiPo, 7.4, 24C or more and Octura X642, and good video camera... :-)
