Results 1 to 10 of 10
Thread: Battery Temps to High. ?
    Nov 2012
    NC
    178
    Default Battery Temps to High. ?
    After a bit of hard running on cool lake water, Temps are as follows:
    Motor 75
    ESC 80
    Batteries 125-130
    Is that normal? ... something incorrect?
    Thanks,
    Mar 2009
    OH
    1,585
    Motor and ESC are perfect. How long did you run and what is the set-up. Batts get hotter as they approach low voltage cut-off. Best not to let bats go below 20%.
    We nee the total set-up picture to evaluate.
    Nov 2012
    NC
    178
    What's the high and low numbers for ' Happy Battery Temps.'
    6 -10 min. run times.
    AquaCraft Wildcat EP, Leopard 3650 / 2450 kv, ProBoat 60amp esc, Stilleto 1.6 x 2.5 prop. 14.4v.
    Oct 2012
    OZ
    266
    50-70degC i've been told, thats for cheap chinese batteries, not sure if that matters or not.
    My 4AH would see 75degC after 5-7mind hard running, no puff ups still balance fine and run great....
    Hope that helps somehow.
    May 2008
    Oz
    2,981
    Quote Originally Posted by TristanJones View Post
    OMG that's some bad advice right there. :shock:
    75'c is terminal for lipo cells....
    Overheated cells fail, and reheat quicker.. .. before they self immolate
    'Optimal' finish temp is below 50'c ( 130f )
    There is a battery header on main forum.. go there for good solid advice.
    burn and learn.
    DocW
    Oct 2012
    OZ
    266
    well there ya go
    Nov 2012
    NC
    178
    Thanks guys!
    Jul 2010
    MI
    3,663
    That's not bad for such a long run. Judging by your temps I would guess that you are running in some pretty cold water...that's the only explanation for your very low ESC and motor temps. I would also assume that if you took ESC temps at the caps they would be significantly higher.
    I use 140F as the cut off for lipos, but I try to keep them cooler than that if possible. Doc's advice of under 130F is pretty reasonable.
    Nov 2012
    NC
    178
    Thanks. ...better now.
    FYI - Temps taken from all over ESC, caps were the hottest, 80.
    Water temp 50-55 :)
    Thanks again,
    Jul 2010
    MI
    3,663
    Quote Originally Posted by 704Authentic View Post
    Water temp 50-55 :)
    Thanks again,
    In that case, it is a little abnormal for battery temps to be that much hotter than everything else. It's ok that your batteries get 125-130 F, but it is odd that the caps are 80 and the lipos are 125-130.
