After a bit of hard running on cool lake water, Temps are as follows:
Motor 75
ESC 80
Batteries 125-130
Is that normal? ... something incorrect?
Thanks,
Motor 75
ESC 80
Batteries 125-130
Thanks,
Motor and ESC are perfect. How long did you run and what is the set-up. Batts get hotter as they approach low voltage cut-off. Best not to let bats go below 20%.
We nee the total set-up picture to evaluate.
What's the high and low numbers for ' Happy Battery Temps.'
6 -10 min. run times.
AquaCraft Wildcat EP, Leopard 3650 / 2450 kv, ProBoat 60amp esc, Stilleto 1.6 x 2.5 prop. 14.4v.
50-70degC i've been told, thats for cheap chinese batteries, not sure if that matters or not.
My 4AH would see 75degC after 5-7mind hard running, no puff ups still balance fine and run great....
Hope that helps somehow.
OMG that's some bad advice right there. :shock:
75'c is terminal for lipo cells....
Overheated cells fail, and reheat quicker.. .. before they self immolate
'Optimal' finish temp is below 50'c ( 130f )
There is a battery header on main forum.. go there for good solid advice.
burn and learn.
DocW
well there ya go
Thanks guys!
That's not bad for such a long run. Judging by your temps I would guess that you are running in some pretty cold water...that's the only explanation for your very low ESC and motor temps. I would also assume that if you took ESC temps at the caps they would be significantly higher.
I use 140F as the cut off for lipos, but I try to keep them cooler than that if possible. Doc's advice of under 130F is pretty reasonable.
Thanks. ...better now.
FYI - Temps taken from all over ESC, caps were the hottest, 80.
Water temp 50-55 :)
Thanks again,
