Results 1 to 27 of 27
Thread: What's the best long distance radio??
    Jan 2012
    NJ
    605
    Default What's the best long distance radio??
    Finishing a build and need a long distance great radio setup for my big mono? Any suggestions?? Not a fan of spektrum and tactic seems to be hit or miss with distance. My Traxxas Rx/Tx from my Spartan worked real well. Suggestions?
    Aug 2012
    ma
    1,361
    Many would say Futaba.
    Jan 2012
    NJ
    605
    Any futaba in particular?
    Aug 2012
    MO
    355
    Read a test on rc soup or big squid and it showed Futaba at nearly twice the distance of other brands.
    KartRacer ~ Dennis B
    Delta Force Pirate 35'~Leopard 4092~1480Kv~Seaking 180~2X6S 65C 5000 Mha Dynogy Lipo,Parallel
    7,279
    Why is distance so critical...you won't be able to tell if its coming or going .
    Jul 2010
    Fl
    761
    any futaba 3prka or 4pk-r just be sure to keep the rx dry
    Dec 2009
    2,041
    Flysky GT3B tested to 2 miles, not sure you'd need much more than that.
    http://www.jrcbd.com/showthread.php?...l=1#post592813
    Aug 2012
    fl
    146
    Buy a futaba. I have tactic, spektrum, and futaba radios and I would rate them 1. Futaba (never loses signal as long as you keep it dry) 2. Tactic (rarely loses signal) 3. Spektrum (regularly loses signal) others may have different opinions but I wouldn't have a flysky as I have witnessed 2 major crashes over the receivers failing
    Jan 2008
    VA
    3,070
    Futaba 3PM. You can a used one for a reasonable price on ebay. Despite some saying you do not need an antenna outside the boat, mount one anyway for maximum range. I'm with devo that the Futaba recievers can glitch if they get wet. Nothing a shot of wd40 and burst of air won't immediately cure.
    Jul 2010
    NS
    577
    im still blown away by my crappy GT 2 and GT 3 HK radios, all still working well!
    Jan 2012
    NJ
    605
    Wow guys thanks for the input !! I need a glitch free long distance combo for a large 65" mono build and need good range.
    Jan 2012
    NJ
    605
    Wanted to avoid a antenna if possible
    Jan 2008
    VA
    3,070
    Let me elaborate on the Futaba wet reciever glitching. Then only time I ever had a problem with my Futaba FASST radio is when the boat flooded and I didnt take time to ensure the reciever was dry before the next run.
    If you want maximum range, the line of sight between the transmitter and receiver must be unobstructed. Anything less and your rolling the dice.
    May 2009
    3,180
    2 on that:
    DJI Drone Advanced Pilot
    Canada
    Aug 2010
    AT
    568
    There is also UHF signal for extreme ranges.Many people use them for fpv with range <25miles but you need a tx with module.
    Jul 2010
    3,663
    Skip the flysky stuff. Bad news when they malfunction.
    Jan 2012
    NJ
    605
    Okay guys I'm sold on the Futaba. What's the best setup Rx/Tx then? Fasst system?
    Jul 2007
    or
    1,088
    I've run Fasst for years, very reliable. I run stick radios so I started running an 8J FHSS system last year. Either system works great. I've never had one come unbound (except for one very wet receiver), even in my very small carbon SAW boats at pretty good distances.
    My .02
    YMMV
    Brian "Snowman" Buaas
    Team Castle Creations
    NAMBA FE Chairman
    Jul 2007
    Ga
    200
    Quote Originally Posted by DK535 View Post
    Most any 2.4 system will have extreemly short antenna length, keep in mind that altitude is a major factor in extreem radio range. (I don't think you REALLY want 6,000 feet range) if you do, stand on a hill or a ladder for maximum range.
    Having said that, I personaly mount my Futaba reciever with the antenna inside the fiberglass hull, up high near the top of the transom.
    I get super range with that setup, at about 1/3 of a mile away ( around 2,000 feet away)
    I can barely see my model (radio range exceeds your vision) and the sound is delayed due to the distance, it has a wierd effect on your senses...
    60" Expresscraft SuperCat
    (2) 2028 Castle motors 64.7 mph
    10s3p with x450/3 props
    15,000 mah 40c cells,
    Aug 2012
    MO
    355
    I bought this one. Seems to be very good. Have always had good luck with Futaba.
    Futaba 4PL 4-Channel 2.4GHz S-FHSS Radio System
    Jan 2012
    NJ
    605
    Wow sloppy that's crazy!
    WA
    8,335
    If you are running a modern Spektrum system, using the MR-series RX's, and you are "regularly losing signal", you are doing something wrong, or have the worst luck on the planet...
    Darin E. Jordan - Renton, WA
    Jan 2012
    NJ
    605
    Ok guys time to order.... The Futaba FHSS system or the FASST system?
    UK
    70
    FASST is more expensive , but probably has the edge on features
    Jul 2007
    Ga
    200
    fasst
    Dec 2012
    sa
    101
    try these one they seem to never lose signal if you have the RX in a ballon http://www.hobbyking.com/hobbyking/s...io_System.html ,these radios have all the digital screens and buttons like the spektrum and futaba and they also have a real good range
    Jan 2012
    NJ
    605
    Thanks everyone for your input ordered a FASST system last night
