Have you tried Z-Poxy. Pretty thin and takes overnight to dry. Looks good and will run a little to leave the finish real smooth.
The extended strut will help move the prop back and acts like it moves the CG forward when the boat rocks back and rides on the keel and prop. However if the boat is running tight extending the prop back will not help too much. Ideally you need to lower the prop to lift the hull out of the water more.
Tyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WR
This will will be be my second build. I plan on building the delta force 35. Does anyone have basic building instructions? And parts recommendations? Thanks, Bruce
Hello Shawn, I am looking for parts recommendations and basic instructions installing motor mounts, battery mounts/box, water proofing and epoxy glues. My email address is Bruce.engstrom@gmail.com. Thanks, Bruce
