Results 1 to 20 of 20
Thread: 120amp seaking with a 4074
    Aug 2012
    fl
    146
    Default 120amp seaking with a 4074
    Is a 120amp esc enough esc for a 25 inch delta force v hull running a 4074 2200kv on 4s? I will be running somewhere between a 440-444 prop for this
    Jun 2008
    OH
    2,345
    Ya that motors way to big for the hull.
    120A wont work, 180A.
    Aug 2012
    fl
    146
    Thanks for the opinion but ive been running this motor in this hull with a swordfish 200 for a while now with no issues, problem was I put the swordfish in a new build and it blew up, so im wondering if the 120 will work
    Sep 2010
    nj
    4,289
    Yes,
    I am running that motor and a t120a esc on 4s and a x646/3 prop in a 36"PB Shockwave,
    Modded to FE.
    I just had to add three 1000ur caps to the esc to keep the temps down on them,
    Runs very nice at 42 mph and about 6 minutes of run time on 2x4s 30c 3600mah packs.
    Aug 2012
    fl
    146
    Lenny thanks for the input, I have a stiletto with a 120 on5s but it's on a stock proboat 1800kv motor and with a 442 prop consistently get 56 + mph, it does have a lawless 3.5 though, which makes quite a difference compared to the stock outdrive.
    Sep 2010
    nj
    4,289
    Have any videos of it running ?
    Mar 2009
    MI
    6,453
    That esc will melt down. Your motor can and will pull well over the rated 120 amps. Go with the Seaking/T-180.
    Aug 2012
    fl
    146
    Quote Originally Posted by Rumdog View Post
    What do you think about a 3674 1900kv on a t120 in the 25? I would probably run 5s on this set up
    Aug 2012
    fl
    146
    Quote Originally Posted by lenny View Post
    I have a friend who takes pics and vids of our boat club & will see what I can come up with
    Sep 2010
    nj
    4,289
    What setup are you talking about that will melt down ?
    Apr 2011
    tx
    1,284
    As long as you stick to 4s and don't go big on the prop it will be fine.
    white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
    Mar 2010
    MA
    3,573
    120 could be ok. I run same setup but with 180 which is prolly overkill
    Mar 2010
    MA
    3,573
    I'm planning on running it on 5 s
    Nov 2008
    Ql
    3,169
    Devo.
    That T120 will easily spin that motor in the 25" delta with those props. I've run that combination in hulls up to 32"
    Two things though. Add a couple of capacitors for insursance. And get yourself an X440/3 prop rather than going up to a 44mm size. The boat handles much better in my opinion with three blade props. Less torque roll than with bigger diameter props. More stable in the corners too.
    Aug 2012
    fl
    146
    Okay, here is an update on what ive decided to do. I sold the 4074 2200kv motor and plan on going to a 3674 1700kv leopard motor, a seaking 120 esc, and run it on 4 & 5s, what do you guys think about that setup?
  16. #16
    Mar 2010
    MA
    3,573
    It'll be fine. I run the exact same setup in my Titan 29 with tfl 444 prop. On 4 and 5s without issue. I'm getting 50 on 5s
  17. #17
    Mar 2010
    MA
    3,573
    I agree with 785 on the 440/3. It is really smooth and a good prop for the little hull. I've tried several props, 444,440/2,640,m445,642 and the 440/3 is my fav
  18. #18
    Aug 2012
    fl
    146
    Ive got a 440/3 blade S&B that im gonna put on it when I get the new stuff, im hoping for mid 50's on 5s
  19. #19
    Mar 2010
    MA
    3,573
    Oh yeah you def will. My Titan is much larger bulky hull running two 5s packs. It kranks. Also try the 444, it's my other fav prop. I'm planning to do 5s with the 2200 lol
  20. #20
    Jul 2012
    Tn
    1,202
    I run a 120 on a 4074 2150kv and it works great just run it and run 53mph in my mystic 29 temps come off at 110 esc and 74 motor
    Sent from my DROID RAZR using Tapatalk 2
    Im Only Responsible For What I Say Not For What You Understand
