Results 1 to 26 of 26
Thread: 8XL with stock ESC
    May 2007
    no
    415
    Default 8XL with stock ESC
    hello gents
    seems my motor needs to be replaced... i ve noticed a few people run an 8XL with hydra 120 ESCs... would the 8XL work out with the stock ESC ??? my educated guess says yes since it s about a 2100 kv motor... i can run an ammo (2300kv) with the stock ESC so the 8XL should be ok then ?? sound reasonable ??? please inform the misguided aussie...
    noticable speed increase ?? maybe a couple of mph ??? i d eventually like to upgrade to a better ESC but for now i ll need to stick with the chinese maded aquacraft stuff...
    cheers
    Mar 2008
    WI
    258
    Default 8xl
    I don't think you can run a 8xl with the stock esc even with a tiny prop. Doby has a 9xl in his with the stock esc and seems like it worked great for him. I'm unsure about the ammo even unless you run a small prop and either way you won't have any headroom which is a good idea. If your sticking to the stock esc for a while I would search for doby's boat with the 9xl as an upgrade. My .02 .
    SV 27,brushless mini vee,renegade rigger,twinstorm,micro drifter,super hawaii , 1/12 miss budwieser
    ma
    8,693
    The 8xl will out amp a stock sv esc. It may be possible to run a small enough prop to get away with it, but what fun is that.
    Steven Vaccaro
    7,279
    Mine takes a 9XL with no problems at all, going on 2 years in one boat.
    Put a 9XL in it and you WILL notice a major speed increase. It also gives more flexability in props.
    ca
    6,963
    Default re :
    I totally cremated a stock SV speed control with an Ammo 2300 on my TS-2. [The OB lower unit does cause a higher current draw however.] Beware !
    May 2007
    no
    415
    sweet... hey doby, what prop(s) do you use with the 9xl ? that motor is the same size diameter as the standard SV motor yeah ? so my OSE water jacket will fit...
    got a photo of the inside of your SV... sorry if you ve posted this before
    thanks for ya help
    oz
    May 2007
    Oz
    95
    Default prop selection
    Don't go pass Octura x642 - x645 sharpen & balanced!! thats what I'm using thanks to forum - Ive also tried and gotten away with on a few occasions GrimRacer L42 x 66 Lifter Prop heart stoppin
    May 2007
    no
    415
    i have an octura 642 here that i haven t bothered to use... i ve had good luck with the CF45 as well as the x440... maybe i should try out the 642...
    doby, what are you running with the 9xl and stock esc ?
    Jul 2008
    ID
    67
    Default 8xl or not
    Now i'm getting worryed, I was told that this was an 8xl motor but I have the stock sv speed control and it all works fine. How do you tell what motor this realy is?
    Do It in Vinyl !
    Jul 2007
    WA
    404
    comfy numb - I don't think it's a problem of it not working (and that's not what the others that have given input have stated either), it's a matter of will it last for more than one run...
    What I'm reading (and what I've experienced) is the amp load on the stock ESC is near the limit with the 8XL...likely over the limit with even a 642 IME (running an 8XL in a slightly bigger hull). The extra pitch of the 642 is enough to spike your amps over the ESC's limit, especially in a mono.
    KV is the only way I know to tell Feiago's apart, is it etched on the motor? perhaps on the front cap which is obscured by the motor mount? if not, I'm not sure how to tell without some testing gear.
    PS - I like the CF mods and the blingy blue locknuts...the stringers are CF too? wanna sell me some? show us some more!
    cheers,
    -Corey
    1,711
    Average amp calculations for a mono hull using a 8XL motor on 4s:
    X432 - 44 amps
    X435 - 63 amps
    X437- 80 amps
    X637 - 96 amps
    X440 - 95 amps
    X640 - 120 amps
    X642 - 140 amps
    ReddyWatts fleet photo
    Jul 2007
    WA
    404
    Default There you have it...
    That's great info Reddy...maybe you should post it in the reliable BL thread too.
    is that data gotten from FE calc, or your own data gathering?
    Do you have similar data for other props/motors?
    Jul 2007
    mn
    658
    Here ya go this is a real good chart to have....
    1,711
    I used FeCalc for those numbers. It will give good ballpark figures for 2 pole motor setups. Still a great tool to get an idea about which prop to start testing with. It does not work as well for 4 and 6 pole motors.
    Aug 2007
    La
    265
    Wow I didnt think an the stock esc could handle the an 8 or a 9XL,just because of the physical mass of the motor pulling more amps
    S.S.R.C-Southern Style Radio Control
    1,711
    Right, the largest prop to use safely for an 8XL with a 45 amp SV controller is a X432 prop and for a 9XL its a X435. These props are not big enough for the SV hull. Needs a bigger controller for these 2-pole motors.
    Aug 2007
    La
    265
    so if I put a 9xl on a x440 im going to pull major amps and blow the speedo
    1,711
    It will be around 75 amps on 4s and under 40mph.
    Aug 2007
    La
    265
    pointless
    May 2007
    no
    415
    my set up runs sweet with the 9xl stock esc and an x440...
    1,711
    I have heard of people using 6s with BEC on the blackjack esc and now you are using 75 amps on the SV esc? Is anyone else doing this or is it going to fry?
    May 2007
    no
    415
    doby runs the same... he gave me the idea... he s been running his SV that way for a couple of years i believe...
    1,711
    What kind of speed are you seeing with this setup and why did you change from the SV motor?
    May 2007
    no
    415
    why - because i can
    as for speed differences, i d say 5mph max... def'n increase in torque... you have to be a little less trigger happy with the throttle or she ll just prop stand and flip...
    Aug 2007
    La
    265
    what are your temps
    May 2007
    no
    415
    i don t use a gun but they are not bad at all... i d say 120 tops for the batts... they get the hottest... the esc barely warms up..
