Twin Accellerator Cat Build:
I was going to run my Cat on 12 cells ??? what was I thinking ??? There is not much room for 12 cells and I would like to place the battery's low in the hull, Hmmmmm Lipo's seem the way to go.
I am running two SV 27 BL motors. I think the KV is around 18,000 ??? Am I correct on this assumtion ??? The ESC's are X-Power Brushless 100 amp Esc from OSE.
What battery configuration is best for my set up ???
I figure the Mha range would be above 4000.
I already have the Great Planes PolyCharge4 DC 4 Output LiPo Charger. It will charge up to 3000 Mha (manual settings).
Will this charger work for higher Mha batteries ???
What is a good Lipo battery and what Lipo's do you want to avoid ???
Tanks a Million
