Results 1 to 7 of 7
Thread: Swordfish 120A ESC on 5S?
    May 2009
    535
    Default Swordfish 120A ESC on 5S?
    Wondering if it's a bad idea to run a Swordfish 120A ESC on 5S with an ARC 1850kV in a JAE 21?
    I let the dogs out...
    Jul 2012
    Tn
    1,202
    you should be fine on 5s thats gonna put you about 33-35,000 rpm i would just run for a minute and check temps and run another min and check again i run a 1900kv on a 120 seaking and it does good all dependent on your prop selection i use a m454 on that setup
    Im Only Responsible For What I Say Not For What You Understand
    May 2009
    535
    Thanks.
    I was thinking about starting with a pitched H5 (45.1 x 80.8 x 114.3 mm) or my m445 (45.1 x 73.7 x 95.3
    mm); third number is the added cup.
    The stock X445 is about 45 x 63 mm, so my m445 is closest except for the cup.
    Pete
    Jul 2012
    Tn
    1,202
    I meant to put m445 my bad
    Sent from my DROID RAZR using Tapatalk 2
    Sep 2010
    nj
    4,289
    I added 1000uf 35v caps to my 120a esc,
    Helps keep thing cool.
    May 2009
    535
    Quote Originally Posted by MAMBA2200 View Post
    Yeah, I've got a 454 but it's in my other boat...
    Jul 2012
    Tn
    1,202
    Very nice
