Hello,
for next season 2013 i am going to build my new boat. It is 930mm long custom build carbon/kevlar catamaran hull. I wasnt sure about the suitable hull lenght, beacuse my intention was fast setup, but i didnt want to ruin my wallet much :-) I Thing that under 1 meter long hull will be enough for good speed, reliable setup and low budget boat. We will see.
I am not boat racer. I only want fast boat for holiday bashing. I will build twin motor powered boat, just becasue i like the roostertail and handling of twins. Nothing more.
There is my custom made hull. It is carbon aramid hull. Bottom part of the hull is carbon/aramid, hatch and top part of the hull is aramid only. Resin is high strenght epoxy with aerospace certification. Hull is tempered, unfortunately not vacued. Next time i will be smarter.
I am not sure about HW i will use. I am only sure i will use wiredrive. It si simple, cheap, reacheble, reliable and efficient.
I am not sure, what motor, ESC (most likely T180) or battery i will use. I want to run only 6S configuration batteries, because all other boats i have i use 6S. I would love to try 6S A-Spec Nanotech 6600mAh 65-130C in 3S+3S configuration. Each pack in sponson. I prefer very light setup, all the build will be build within this phylosophy. All components will be as light as possible. Just try to look on 6600 Aspac nanotech - power/weight/capacity ratio.
