Originally Posted by
Sigurd M
hi, first post in th new forum :) looks good....
does anyone know if the teflon liner steven sells for .150 flex cable is ment to have inside a brass tube or just use it as it is?
i also wonder if there's some sort of sleeves I have to have inside my strut if i buy the stinger strut for 3/16 prop shaft, or does it work as it is? and how long does the prop shaft have to be to use this strut?
all help appreciated,
thanks
Teflon isnt strong enough, you need to put it in brass. I like to only keep a little at the end unsupported.
The stinger comes with a sleeve. You need a cable and propshaft for it to work.
We use a 2 1/4" long propshaft.
Steven Vaccaro
