Page 11 of 16 FirstFirst ... 910111213 ... LastLast
Results 301 to 330 of 478
Thread: BBY Micro Turbine Hydro for SSSH
  1. #301
    Sep 2007
    1,707
    Quote Originally Posted by Sneasle View Post
    ya, I could probably use some. I was planning on using some 2" wide fiberglass strips I have for joining airplane wings.
    Dr. J, I got the frames in today. I test fit a set together and I noticed something. The long side lengths and the center cross brace fit together well. The motor box went together relatively easily. The front T- Brace went together easily as well. That leaves two pieces, which I assume one is a transom doubler that connects to the long length that is left that plugs into the center cross brace some how.
    I think I see the slot that was cut for it to plug into, but that slot is directly underneath the hole for the cf tube, which the slot on the transom double is offset by 1/4" or so....
    I'm not entirely clear on your description. I'll post more photos in a day or two. All the parts fit perfectly in my set. Double-check the existing photos. There should be two turn fin doublers and two transom doublers. They are small and may be hiding in the corners of the envelope that the parts were in. There is a center stringer that looks like a ladder that goes from the center bulkhead to the transom. The straight portion of this faces up, the portion that has a small angle in it faces down. The stuffing tube attaches to a portion of this.
    DO NOT GLUE ANYTHING until you are 100% clear on how the parts fit together.
    Double-check this photo:
    https://forums.offshoreelectrics.com/...4&d=1219453540
  2. #302
    Aug 2008
    AL
    197
    Ya, the center stringer goes back to the transom, and there is another piece that closes off the 'rectangle' at the back of the hull. That center stringer is offset on the transom end, but it isn't offset on the cross brace end.
  3. #303
    Sep 2007
    1,707
    I wonder if the laser guy used the old drawing? Post a photo of it, and I'll send you another if it is off.
  4. #304
    Aug 2008
    AL
    197
    well, the issue is that on the center cross brace the the slot for that center stringer is in the middle of the cross brace, right under/over the CF tube, but on the back/transom part of the box, the slot is off center by about 1/4".
    I'll try and get a pick up when I get home and I'll check the second one to see if they match up.
    edit: I ordered from you last, and the frames beat the hulls and motor/esc here! Nice.
  5. #305
    Jan 2008
    716
    For CF fabric check on ebay there is usually some for sale there.
    Peter Eells; Fun, and Helping others To Have Fun!!!
    http://rcboatsbypetere.blogspot.com/
    RC.Boats.by.Pete@gmail.com
  6. #306
    Sep 2007
    1,707
    That center brace is supposed to be right over the CF tube, but the entire motor assembly should have been shifted 1/4" as well. I think I better check all the remaing ones I have. I just grabbed one for my own build and it was correct. I didn't check every one in the group. I'm thinking there may be a mix-up somewhere. I'll double-check the drawings when I get home tonight.
  7. #307
    Jul 2008
    ca
    76
    what weight cloth? all I can find so far is 6 oz a square yard, sounds heavy????
  8. #308
    Sep 2007
    1,707
    5.7 oz. is about all that is readily available. You want stiff? That will do it for you.
  9. #309
    Sep 2007
    1,707
    I just checked the drawings that went to the laser guy, and they are correct. Here are a couple of photos of the frame temporarily installed in the hull. Maybe they will help.
  10. #310
    Aug 2008
    AL
    197
    ok, I think I'm good. I see where the offset is on the center cross brace. I don't think I had the offsets in the same direction.
    I think I see how this is supposed to fit together now. I guess it would help if I had my hulls so I could match the curves in the wood to the curves in the hull.
  11. #311
    Sep 2007
    1,707
    Look at the part of the center bulkhead that goes in the sponson. On one side there is a solid area where the turn fin will attach (see previous photos in this thread). The motor is offset towards this side. It is possible to put this piece in backwards, so be careful before you add glue.
  12. #312
    Aug 2008
    AL
    197
    I'll post pics as I go and let ya'll ok them before I hit anything with glue.
  13. #313
    Aug 2008
    AL
    197
    I'm starting to get kinda worried... no hulls yet .
    Any more progress Dr. J?
  14. #314
    Sep 2007
    Co
    3,915
    Are you the guy in Alabama? If so the hulls were delivered yesterday.
    Randy
    BBY Racing
  15. #315
    Aug 2008
    AL
    197
    Quote Originally Posted by RandyatBBY View Post
    Really?
    ummm............
    Is there a tracking number on them?
  16. #316
    Sep 2007
    Co
    3,915
    Really?
    ummm............
    Hear ya go #xxxxxxxxxxxxxxxxxxx4298 USPS
    Randy
    BBY Racing
  17. #317
    Aug 2008
    AL
    197
    Hear ya go #0306 1070 0004 6945 4298 USPS
    Claims 11am this morning. Sounds about the right time the mailman come by.
    Hopefully I make it home before the office closes, looking forward to playing with these guys.
    I guess you can ignore my email now :).
    Thanks Randy.
  18. #318
    Sep 2007
    Co
    3,915
    Not a problem, glad to help. I removed your tracking id save your ID.
    Randy
    BBY Racing
  19. #319
    Aug 2008
    AL
    197
    Got them. Looks pretty cool. I assume the wood pieces are for the patriot?
    Oh, and I was expected 5 sticker sheets... I got only one .
  20. #320
    Sep 2007
    Co
    3,915
    No They all get transom doublers. I did not know that you were getting Dr Jets frame work.
    Randy
    BBY Racing
  21. #321
    Aug 2008
    AL
    197
    Ah, that explains it.
    I got his frames for the Hydro, so I'll use yours for the others.
    Stickers?
    Edit:
    Dr. J, what kind of connectors did you use on the motor/esc leads? I noticed they didn't come with anything.
  22. #322
    Sep 2007
    1,707
    Stickers?
    Edit:
    I use 3.5 mm bullets on the motor/ESC side. Male on the motor, female on the ESC.
    I managed to get the framework waterproofed, so maybe this weekend the frame will get glued in.
  23. #323
    Aug 2008
    AL
    197
    Quote Originally Posted by Dr. Jet View Post
    how are you waterproofing it?
  24. #324
    Sep 2007
    1,707
    I paint it with thinned epoxy.
  25. #325
    Sep 2007
    1,707
    I've been busy with other things lately. I finally had a chance to stick the reinforcement on the tunnel floor. I weighted the hull down on a flat board to help keep it from twisting.
  26. #326
    Aug 2008
    AL
    197
    good idea.
    What was your source for the CF mat?
  27. #327
    Sep 2007
    1,707
    http://www.dmc-ca.com/
    DMC is also my source for the 4:1 epoxy.
    That was the last of my mat as well and the weave has been messed up before I put it down, so it isn't as pretty as I would like, but it is still functional.
  28. #328
    Aug 2008
    AL
    197
    kk, sounds good. I'm having a hard time navigating their site. I'll check cst and see what they have as well.
  29. #329
    Aug 2008
    AL
    197
    Would this stuff work for the floor reinforcement?
    http://www.cstsales.com/carbon_tissue.html
  30. #330
    Sep 2007
    1,707
    Use a couple of layers of the .5 oz. stuff in the tunnel, and add some extra layers in the motor mount area, and you may have it about right.
