Results 1 to 15 of 15
Thread: Gluing Pool Noodles ?
    Aug 2012
    VA
    161
    Default Gluing Pool Noodles ?
    What adhesive can I use to glue a piece of pool noodle to my Cheetah hatch? I'm just not real sure what will stick to this foam & fiberglass.
    949
    Try a hot glue gun, it should stick.
    Aug 2011
    oh
    625
    Hot glue wont stick, I use gorilla glue.
    Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
    Jan 2008
    VA
    3,070
    Goop works great Chip. How's the Cheetah coming??
    Aug 2012
    VA
    161
    I ended up using 5 minute epoxy and it worked great.
    Chilli, Cheetah is done except for a splitter I need to run 2 packs. I just need about 6 inches of 10 gage to finish & run.
    Chip
    Apr 2012
    Md
    121
    looks good chip
    Sep 2012
    IA
    274
    Something else works and that is small bubble plastic and CA and takes up less room where room is sparse. Also you can attach a piece of chalk line to cover and to boat away from motor area so it doesn't get wrapped up in cable. Both items work for me.
    Jan 2008
    VA
    3,070
    Looks Good Chip. I tried epoxy and it didnt hold as well as I thought it did. But in your application, you'll be fine. If you put a little floation on your hatch, I wouldnt trust the epoxy though.
    Glad you went with good quality packs. Take good care of them and they will last for years. If you want to go for a quick test ride, you'll be okay running 1P for a minute or two. You want to do that any way to make sure your set up isnt running hot. Just run the second pack the same length of time as the first till you get a Y connector soldered in place.
    Dropped by the pond today to see if the grass seed I put down took. It was all gone. LOL Heavy rains a few days after I put it down probably washed it away and the birds ate the rest. There were tons of geese but a flock of gulls occupied the launch area. There was very little goose poop in the launch area. My guess is they dont like walking on gravel but they loved that old carpet we put down. LOL Anyway launch area looks good. Should be allot safer.
    Jul 2010
    NS
    577
    Ive actually been told that .... Silastic is what your supposed to use
    I havent ever tried it though. somthing to do about its chemical properties etc
    Marine GOOP works great for me. I just pulled out a piece of foam I glued into a hatch five years ago - it was hard to pull it out, still stuck very tight. Plus when you remove the foam you can remove the remaining GOOP relatively easily - unlike epoxy.
    Aug 2012
    MO
    355
    Great looking build!
    KartRacer ~ Dennis B
    Delta Force Pirate 35'~Leopard 4092~1480Kv~Seaking 180~2X6S 65C 5000 Mha Dynogy Lipo,Parallel
    Aug 2012
    VA
    161
    Thanks for all the replies
    Chip
    Sep 2012
    IA
    274
    That boat is clean and neat in side, my hat goes off to you!
    Aug 2012
    VA
    161
    Aug 2012
    VA
    161
    Tried my hand at decorating with leftovers. Not much bling but, It's mine.
