well i just bought a MC so i guess i will be building another any tips for a new MC owner i will be using a swordfish 200a esc
im gonna be running a 4074 2150kv on 4s in my motley will i be able to pull a grim45x68 prop or a m545 with no issues
Im Only Responsible For What I Say Not For What You Understand
Mine runs fast and clean with an AQ1800 and AQ60A ESC. Spinning an m445 it hits high 40s in race water, I'm not sure I'd want a little light boat like this going too much faster. Mine is a bit different than most....
Well i bought it as just a hull no electronics so thats what i have to go in it was just wondering if that motor would pull thise props and i will have a swordfish 200a esc
Sent from my DROID RAZR using Tapatalk 2
I'd drop down to an m445 first. Both of the other props will load the motor more than the m445 will, depending on your packs that may be too much. You will want a low lift prop on that cat, the 45x68 has more lift than the others and more load too.
