A couple more...
A couple more...
And she found her new home in Florida. Should have her dialed in tomorrow. Will post speeds and set ups. Beautiful boat my friend. Thank you.
Will be waiting for speeds too, to add them to the HPR speedlist, already got the pics from Kent!
Enjoy it, its a really awesome boat and lets call it "capable setup"!
regards,
Manuel
First dialed in run. With 7S 5000mAh (heavy lipos) and 447"s in wye she ran 85.6. Nothing heated up over 100.5*. Everything stayed cool. Gonna run 8S tomorrow 2X4S 4000mah. After tomorrow will try 5S delta. Manuel or Kent, should I try 450/3 tomorrow on 8S?
I don't think you will win a lot of speed with those props, as the total pitch is not far off from the 447's. They may benefit a heavier boat where slip is more of an issue. I would definitely stick to the 447's on 8s, but for high speed switch to delta and give it a try on 5s. Not worth loading the up the system with those 450/3's. something with a smaller diameter and more pitch might do the trick if you want to run on 8s maybe a set of 4518/3 or 4516/3. Could also work with a set of cut down 57's to 48-50mm but maybe only for short runs. Just on a side note. Your 2250's in the HPR has pushed the MHZ138 to 87mph with a set of 448cnc on 8s. No drama there!
That is absolutely gorgeous! I'd love to have you build me a boat like that some day :)
My compliments, a beautiful build.
