Any suggestions for prop for 22.5 mono running 2860 3400kv, 120a ESC. I tried running on 3s but i think it was to much. I am going to try it on a 2s. Looking for prop suggestions. Thanks!
Running an Octura .150 cable system for 3/16" props.
On 2s I'm thinking an x440/x442...........possibly even an x637
Is the mono you are talking about the R2 Hobbies Arowana? If it is I have one ( wife's boat ) It has a 2223 2900 out runner running on 3s 2200 batteries and running a 35mm prop doing 25-30.
Yes thats the mono.
I have a wire drive in mine with a 1/8 inch prop shaft and run both 32 and 35 mm props on it and it flies for a little boat. Just can't get it to self right it's self.
I have no issues with self righting. I tried running it on 3s but it kept going airborne. flipped over each time. going to try 2s
where do you have your strut set? mine is level with bottom of the hull and I put on a set of trim taps. Runs real dry and flat.
Here is a small video of wife running hers with me and my Sv27
Yes strut is level to the bottom. Both boats look like there are running great!
Did you have an issue with chine walking? Mine walks pretty bad.
No, always runs smooth
I thought maybe it had to due with all the weight on the port side.
I have everything but the rec. on the port side.
Thanks for your responses. I raced cars for years. New to boating. Lots to learn.
me to, just sold the last 2 I had. Still have 36 airplanes that dont fly any more
You sound like me. I either go big or not at all. It's an addiction. Lol
yes it is
I live on a lake. Makes it real easy. This one could get extreme.
I'm about 10 minutes away from one
where at in Mi. are you
I am on White Lake in Highland. Which is close to Brighton if you know where that is. How about you?
Toledo, oh
My sister lives in slyvania
I've run in a pond over there
Do you have a group that gets together there?
Yes there is 3 of us that run together
If you wouldn't mind a fourth, maybe I'll take a run down sometime. I'm close to 23. Fast easy ride to Toledo
No that be cool. Have to hook up next spring, we are all done for this year
Sounds good. I'm gonna run here until the lake freezes. Im going to build a couple boats over the winter. Thinking about a pursuit/bling rocket
