Results 1 to 4 of 4
Thread: 10s bec
    Dec 2011
    Fl
    693
    Default 10s bec
    I'm tired of constantly charging my rx packs. What is the best BEC for 10S. Using a Swordfish HV 240. Thanks guys. I have both Castle BEC's. I'm gonna assume the CC Pro is the better choice. Is there anything else out there?
    Sep 2007
    2,783
    The Castle CC Pro is pretty good, also look at the Western Robotics BEC http://www.readyheli.com/WRL-HBECS7-...k_p_40395.html
    or http://www.readyheli.com/WRL-HBECHV-...t_p_36455.html
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    US
    5,557
    You shouldnt have to charge RX packs but every 5-6 runs at most. If your using 5 cell nimhs of 4000 mah or more they should do it. If you are using anything less, consider using higher mah or a 2 cell LiFo.
    May 2008
    OH
    774
    I use Hyperion LiFo in all my boats, charge once at the beginning of season (1600 mah battery), recharge in middle of season and they are still at 3.3 per cell. Storage charge for winter. UBECS can fail!
