Page 4 of 6 FirstFirst ... 23456 LastLast
Results 91 to 120 of 153
Thread: Hey Guys anyone know what motor I can upgrade to with stock esc?
  1. #91
    Oct 2012
    112
    Went out the other day and did a few runs ended up breaking both my 3 blade sv27 props so I went to my LHS (The good one)
    and ordered these.
    http://www3.towerhobbies.com/cgi-bin...&I=LXRUD6&P=ML
    http://www.horizonhobby.com/products...iletto-PRB4019
    Can't wait to try them
    I also found out that the guy there balances and sharpens props so now I got someone to do it which is awesome.
  2. #92
    Sep 2010
    nj
    4,289
    They should be better than what you had,
    How did you break them ?
    Do you think you hit something in the water two times ?
    Also looking at buying one of these soon.
    http://item.mobileweb.ebay.com/viewi...d=130607328713
    http://www.youtube.com/watch?feature...&v=j4uZjm2yCmA
    http://www.youtube.com/watch?feature...&v=KCvCY-SYuOU
    What do you think of them ?
    ? ONLY IF THEY WORK
  3. #93
    Oct 2012
    112
    I have both the v911 and the v911 fake and there is almost no difference but if you get one get the new plug version
    and http://www.banggood.com/ is the cheapest place to get them.
    Also the first thing I did with both is buy this http://www.ebay.ca/itm/Metal-Inner-S...item3380ed3a4c you don't need to use the whole package but you do want to use the swashplate it makes it run a lot smoother but the whole package adds a lot of weight so your batteries don't last as long.
    Also you should get these batteries http://www.banggood.com/Wholesale-5-...y-p-61723.html that plug on them is the new version.
    This is the old version http://www.banggood.com/Wholesale-5-...y-p-64992.html.
    Any other questions just let me know.
    I've never had or even heard about the H911 but it looks pretty cool.
  4. #94
    Oct 2012
    112
    Went out today and had the best runs yet when I went out the other day I broke both my 3 blade props so these runs are with my Proboat 40mm 1.6 x 2.5 2 blade.
    The best run is with the 8.4volt nimh but I warmed up with the 7.2volt. The water was 32.3F and my temps stayed pretty good except the battery.
    Voltage at beginning of run was - 8.9
    Temps after run where
    ESC - 53F
    Motor - 45F
    Battery - 106F
    Voltage at beginning of run was - 10.04
    ESC - 53F
    Motor - 53F
    Battery - 115F
    I also have some more videos of this day on my Youtube Channel I happened to flip a couple times
  5. #95
    Oct 2012
    112
    man I found this video in my searches on youtube check it out
    this Rio ep rocks.
  6. #96
    Oct 2012
    112
    Well had a bad experience the other day and my Rio met the wall in the pond here is some pics of the damage and thank god for jb weld for plastic.
    Hopefully this will hold and it won't leak.
  7. #97
    Sep 2010
    nj
    4,289
    Looks like a malfunction in the helmet as they say at the races,
    Or look out for the tree as my buddy would say when he hit it in the snow with his Rio.
    If it does leak I would just start modding it like mine,
    Than you will have access to the damage from the inside and fix it good.
    And also make the boat CG and handling better to.
    ? ONLY IF THEY WORK
  8. #98
    Oct 2012
    112
    Ya I was hoping not to have to do that till next season but if it leaks it leaks and I guess I don't have a choice but
    at least I'll have a stronger hull in the long run and I already have the paint and everything to do it.
    Heres the video of the crash and I even seen it coming if I just would have stopped I wouldn't have hit the wall
    but just like you said it was a malfunction in the helmet.
  9. #99
    Apr 2011
    5,666
    Guys, As Lenny said, I have daily helmet malfunction, when I maidened my Mean Machine, I beached the cat twiced in a roll, it was like a landing craft!
    You fix with JB Weld looks really good, I didn't understand, does it still leak?
    The boat rides really well, hope the fix is good for now.
  10. #100
    Oct 2012
    112
    Thanks a lot man my wife helped me fix it and she has more patience than me and I haven't put it in the bathtub yet to see if it leaks
    I just sanded it tonight and put another coat of jb weld on it once it dries and I sand it again I will keep you all posted to let
    you know if it leaks. Hopefully it is good. I think it rides pretty good and if it doesn't leak hoprfully I can get it to ride better.
    My lipo is coming tomorrow and I can also pick up my new props tomorrow to can't wait.
  11. #101
    Oct 2012
    112
    Well I put another coat of jb weld on the boat today gonna sand tomorrow and put in the tub to see if it leaks wish me luck with it.
    Heres some pics of the second coat.
    IMG_20130418_180144.jpgIMG_20130418_180225.jpgIMG_20130418_180301.jpgIMG_20130418_180328.jpg
    I also got my turnigy 2 cell lipo a grimracer 3 blade 40mm prop and a proboat 1.6 x 2.5 steel prop that is balanced and sharpened these should help
    out my top speed a bit.
  12. #102
    Apr 2011
    5,666
    Seems to be a great repair! With some sanding and touching up, you will develope a stronger bond ( no pun intended) with the boat, at least that is for me, I feel terrible when a mishap takes place ( helmet malfunction), then I calm down and fix it and there is this bond that is even stronger.
    Good luck tomorrow!
    Now for a stupid question: don't laugh: where did you find white-colored JB Weld? I thought they are all dark gray color. well, I am missing something as usual...
  13. #103
    Oct 2012
    112
    I've never used jb weld before but the stuff I got is this.
    http://www.jbweld.com/product/j-b-plastic-bonder/
    Its for plastic and it works pretty good for a filler and a bonder.
  14. #104
    Oct 2012
    112
    Amazing no leaks after half an hour I'll keep updating every half hour or so till I hit 2 hours I figure if there is no leaks after that I should be good to go.
    Well after an hour and a half there is maybe a drop or 2 of water in the boat but I don't know where it is coming in it could be around the flex cable tube or in one of
    the other holes in the back so i'll seal them up and try again but the amount of water in it is not really anything to worry about.
    Well its been about 3 and a half hours and still only a couple drops of water inside the boat so little that it wouldn't come out the drain plug so I think
    that is a success so I'll be out sometime next week to test out the new props.
  15. #105
    Apr 2011
    5,666
    Thanks for the link, my life would have been alot easier had I known this stuff, this is good to use on plastics, i.e., ABS, Polypropylene and Polyethlene, etc.
    Great news that the hull doesn't leak! best wishes for tomorrow on your new lipos. Double check your helmet!
  16. #106
    Oct 2012
    112
    Thanks but I won't be trying my lipos tomorrow ya see my batteries came in the mail but my charger i'm still waiting for and that sucks hopefully it will come next week.
    This jb weld is awesome and also easy to use so next time you have a helmet malfunction you should try it cause it worked for me and tomorrow my helmet will be strapped
    on tight.
  17. #107
    Sep 2010
    nj
    4,289
    Hey,
    May be you should make some boat bumper for it,
    For those days that you roll your own and are malfunctioning driving the boat or heli.
    Nice straight long runs to see how it riding and no hair pen turns yet.
    How high are your trim tabs now ?
    Look what I just ordered,
    They will be hear Wednesday.http://www.rcuniverse.com/market/item.cfm?itemId=911441
    ? ONLY IF THEY WORK
  18. #108
    Oct 2012
    112
    Man nice buy i'm jealous the 911 are great but I've never tried the 9958s but I can't see them being to bad at all.
    My trim tabs are about an 8th of an inch high and I think I've given up on hairpin turns for awhile until I
    get a bigger place to run but that's ok I can go faster in a straight line which is more fun anyway.
  19. #109
    Sep 2010
    nj
    4,289
    I run again today with a 3s 30c 5300mah pack,
    And adjust my trim tabs down a hair or so.
    But it still will fly off the water if I go full throttle with it,
    It hit a gps speed of 41.6mph today.
    Than on next run it did a death wobble,
    And than a 180 at about 36mph and bent the rudder bracket a little,
    It still has more power to put to the water.
    I just need to make it run wetter and may be add some weight to the back of the motor mount.
    Than see what it does for speed.
    I need to see yours run with the lipo pack,
    And than maybe adjust for it.
    ? ONLY IF THEY WORK
  20. #110
    Oct 2012
    112
    Did you get any video of those runs I'd love to see that. I'm hoping my charger comes in tomorrow so I can try my lipo but I know for sure I'm gonna try my new Props.
  21. #111
    Sep 2010
    nj
    4,289
    I think the pro boat prop will slow it down,
    Do a 1 to 2 minutes run with it and check temps.
    The 40x52 should be a lot better,
    But check the temps after 1 to 2 minutes.
    You also may have a little more run time with that 40x52 prop.
    I like the x440/3 the bests so far.
    So you want to see my helmet malfunction and speeds.
    Later on tonight I will post some video's of it.
    ? ONLY IF THEY WORK
  22. #112
    Oct 2012
    112
    My faster runs have been with the same proboat prop but its plastic but I can't wait to find out how much difference a metal prop makes.
    Ya I definatly want to see your helmet malfunction and I also want to see that 41.6 mph run.
  23. #113
    Oct 2012
    112
    Well I got out today for the first time after my helmet malfunction and the boat ran great. I ran it with both batteries on timing seting 2 and my new
    Proboat 1.6x2.5 stainless prop and I am very impressed with it. Tomorrow I'm gonna try the grimracer 3 blade and do some tests with it.
    Here are the videos with the 7.2v nimh battery. My starting voltage was 8.3v and my ending voltage was 7.5v.
    Temps
    ESC - 54 F
    Motor - 57 F
    Battery - 86 F
    Temps
    ESC - 59 F
    Motor - 58 F
    Battery - 114 F
  24. #114
    Oct 2012
    112
    Here are the runs with my 8.4v nimh Battery. My starting voltage was 9.64v and my ending voltage was 8.7v.
    Temps
    ESC - 61 F
    Motor -59 F
    Battery - 90 F
    Temps
    ESC - 61.8 F
    Motor - 61 F
    Battery - 127 F
  25. #115
    Sep 2010
    nj
    4,289
    Looking pretty good for first mod to brushless.
    Now bring on the lipo's baby.
    ? ONLY IF THEY WORK
  26. #116
    Sep 2010
    nj
    4,289
    I never saw someone milk a boat before.
    ? ONLY IF THEY WORK
  27. #117
    Oct 2012
    112
    Ya that's funny the water wouldn't come out unless I milked it. I think the water got in when the boat was flipping around because there was no water in it when I was using the 7.2v
    and with that batt there wasn't as much power. What do you think?
  28. #118
    Sep 2010
    nj
    4,289
    Try running it with out the spin outs on the 8.4,
    Also it weighs more than the 7.2 to.
    ? ONLY IF THEY WORK
  29. #119
    Oct 2012
    112
    Ok cool ill try that. If I get some bigger turn funs will it be more stable in the turns and will it also turn faster?
  30. #120
    Oct 2012
    112
    Oh man today was my lucky day I got my Lipo charger in the mail. I went out today and ran with it I am very impressed with the power in the battery
    here are the videos of my run.
