Originally Posted by
bob_t
The blades are well balanced, as they sit perfectly level in the balancer, but when you spin the prop, it always stops with the same side of the hub "down", again with the blades being perfectly level.
Thanks,
Bob
So you have a leading and a trailing edge hanging below the axis of your prop balancer.
If you remove material from those two places my guess is that you'll find a happy place.
Do make sure that you have removed any flashing on the hub before you get started.
Good luck,
Doug
MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
