Just purchased impulse V2, little disappointed in motor to shaft connection, do we know yet if a collet from one of the other brushless boats can be substituted, Geico or Blackjack?
did you see my issues with the boat
Measure it then buy a better one
Billy Graham
Can someone please post a picture of exactly what it is they are concerned with about this collet?? Did they change something from the original one??
I've been running these collets under extreme racing conditions for well over a year and have yet to have a single issue with one. Mine have been straight, secure, and pretty much trouble free. I'm curious as to what may have changed, if anything, or if this is just an "expectations" thing with the complaints??
That being said... OSE sells the Octura 5mm to .150" collets that work very well. You'll probably have to provide clearance on the motor mount under the collet to fit one to the boat.
Darin E. Jordan - Renton, WA
Diameter reduced, back- cuts, balancing and detongueing , sharpening, 42x55 -- 40x55
connector 4mm Gold
cooling hose 1/4x.170 O.DxI.D
servo does not work
esc does not work for high volt cutoff and cutoff type ldle, (can not be programmed with programming card)
not recommend this boat
after 10 day, proboat not have parts for warranty, out of stock
incredible disservice
100_0217.jpg100_0213.jpgProblems begin
servo does not work
Impulse 31 v2 improved
The problem was the color. I change the color and no more problems LOL…..
-Battery 5S 4000 mAh 40C
-Propeller (Battery 5S, motor timing LOW)
42x55 45.4 mph
M445 46.3 mph
42x55 the tongue removed 47.2 mph (timing high 8% more speed and Amp)
M445 reduced to 42mm diameter 50.8 mph (timing high 8% more speed and Amp)
-Cooling hose 1/4x .170 O.DxI.D
-Connector 4mm Gold battery
-ESC front, more weight to the front, batteries more near the CG
-CG 30 % 8” ¾ or 9”
-Improves cooling system
-The antenna of de other side
-Reinforcement of the hull and hatch cover with fiberglass and resin
-Modify the original turn fins
- flex shaft (Miss Geico)
-Adjustable trim tabs
-Homemade bushing
-Hatch lock
-The stock 1800KV motor and ESC 80 Amp (only 5s)
-weight of the boat 4 ½ pounds without battery, with battery 5 ¼ pounds
Manny
Here's one that's a perfect fit for just $10... http://kintecracing.com/Collets_Couplers.html - scroll down to the "Octura Collet, Short For 5mm Motor Shaft and .150 Flex Cable." - Be sure to get the SHORT ONE, the long one will not fit, not enough room.
Problem solved.
Darin,
Are you reducing the length of motor shaft a bit, then putting a flat spot back on for the grub screw??
On my IM (V1), there's just enough room for the short Octura even with the motor mount moved all the way back - towards the bow.
Needless to say, I am interested in your mod.
Thanks for sharing that with us, appreciated.
Texan Rocket. 6s
Hull and hardware Revolt 30 (improved water cooling and hose ¼ x .170 O.D x I.D)
ESC Dynamite (DYNM3820) Marine 80-amp (brushless water-cooled w/reverse)
Motor Dynamite (DYNM3830) A3630-1800kv, 6-pole, water-cooled marine motor
Connector 5,5mm
Propeller. Octura x442--- X440/3.
Battery 6s +40C
Speed: Fast Electric Adict!
manny
