Setting my Atomik 58 up with the 2028 castle motor and castle 200hv ice2 esc. Should I max out at 10s with this motor?
And what prop will work best?
if it were me I would run 8s and use gas size props...
So only 8 s on the 2028? Is 10s too much rpm for motor or boat?
10s is not too much. start with the stock 50mm 3-blade the atomic comes with, then check your data logging. if amp draw and temps are low, then prop up
I think its a cool boat. I would look at one that needs motor esc and radio so that I could modify it to my liking. I wouldn't want the servo ether as I have some already. The motor mount would need to be replaced so that a 56 series motor could fit. or a pair of them for that matter. So does Venom sell the hulls only. this would make warranties easer.
Ive got the KOS, but its the same boat. Im running a Leo 5698 910kv, CC 200HV on 8s spinnin a x452 prop. Even if I go to 10s, I want more prop. The 452 isnt enough. Probably will start at the x455/3 and go up from there. If i had the 2028 (780kv?), id start with the x457/3. Lots of possibilites. Jimmarcums segad on youtube has a Leo 5692 730kv on 12s using a x462, another guy with my setup is using the 70mm prop the gas one came with. Will be trial and error. Anything below 60mm should be safe start on 8-12s from what I've read. Just use that data logger that is onboard the 200HV, and dont use cheap lipos. I used turnigy 4s 5000mah 40c packs, and my ripple voltage was too high. CC said to stay away from those packs on this setup unless I plan on going 8s2p. 4 packs per run didnt sit well with me, so I got the dinogy 65c packs...problem solved.
And to address the steering rod issue. Replace it! Im using the Dubro plastic linkage rods as a pull/pull seup, and it works flawlessly. Super strong and solid.
8s2p ... 10s2p ... 12s2p ...
With a setup this big going 1p is never a good idea
Why is it the guys running twin motors can run 1p per motor all day long, but the single motors suggest 2p? I dont get it!! On my setup, my lipos are barey warm, and I do mean barely. My lipos are good for 325amps, if Im pulling 120amps I would be shocked. Im all ears, but as of now, I dont see the point. Just seems like added weight for some extra run time. Im hardly stressing the packs currently at 1p.
when you have two motors driving a hull they "share" the load... much less amp draw than a single setup
with your packs in 1p config your runtimes with a 120a pull are only going to be 2min
second the 65C "rated" packs are not true 65C packs... some testing at rcgroups shows this... but they still kick butt
even the Gens Ace 25C packs put down some very impressive amp numbers in that testing very very close to them... so that shows C ratings are kinda bogus on some packs
I have a Mono that pulls over 185amps cont. and I run 2p with a X452/3 on 4s
so if I ran 1p during a race my boat will not finish the race...
FWIW
Sunday is my big day for the first run. I have it set up for 6s. I did order a 55mm prop which will arrive next week. Fingers crossed.
5698 910kv on 8s with a x452. Im looking at the x455/3 next.
Looks good from what I can see of it,
You should try standing in the middle of the ponds walkway for better running and video's
This way it would be easier to see how it is running and riding.
But really I just think that boat need a lot more leg room.
Looks like this coming Sunday will be video day. Last Sunday the ESC decided to retire. I will start with the stock prop and then try the X455/3 that I just received. I did balance and sharpen it.
I did hit 38.1mph before the ESC went bad. I was running on two 3S 5800 Turnigy packs in series.
For those three minutes I was impressed with the speed and handling. So were the other forum members watching.
is the newest version of this boat a 180Amp esc? Some sites are advertising 120Amp, and some the 180amp. It would really suck if i ordered from a site that says 180amp and i get a 120Amp.
Wow that video is pretty impressive. Nice work
They did warranty it. I showed proof of when I bought it, which was only a couple of weeks ago.
shopper here you go!!!
http://www.ebay.com/itm/Atomik-Hull-...item4857b17141
Overpriced much? Holy crap! For $900, i'd rather buy the Central RC 73" mystic and a set of drives.
$899 is more then Tower. I have the Atomik and I am very happy with it. With no fine tuning I went 38mph stock out of the box. I am the person that would rather buy a turn key (RTR) then build it at this time. I do not work for the company, but I think and also the people that are on this forum have seen it at the lake agree with me when I say the quality of workmanship is very good. I know there will always be the haters, but nothing will ever satisfy them unless it is for free. I also wonder if they have seen it or had the opportunity to operate one. Not starting a war here, but for a RTR it is top shelf. I am fine tuning it so I can hand it over to my 8 year old son.
I understand that you can build a similar boat for less. I have done my homework on building a boat, but thought I should buy a RTR to get started with and see how and why so I can build mine. No regrets here.
Tower has the RTR for $909 (minus $90 coupon) with free shipping.
