Results 1 to 6 of 6
Thread: Battery recomendation?
    Jun 2008
    3
    Default Battery recomendation?
    Heya im making up a rigger at the moment and am going to run a feigao 540 7xl in it with a hydra 120 esc, im a little unsure of what size lipo battery to run with it. Any help is greatly appreciated.
    Tim
    Br
    2,406
    How big is the rigger? My xs2 on 4s with a hydra 240 & 4s with the 7xl & x640 prop was 60mph. The same set uo with a 1512 2d is 65 plus. You can run alot harder set ups in the rigger due to less drag. The same set up in a mono would be a disaster.
    Jun 2008
    3
    heya its around 26" and is going to be full carbon apart from balsa sponsons, at this stage anyway
    May 2007
    1,603
    Sounds like about the same size as my Matrix rigger and I run 4s in that. As with any setup just check temps alot and have fun.
    Team Liquid Dash
    Dec 2007
    Az
    1,022
    4S Lipos 4900-5000 mah's. 25 C cells. X438 prop to start with to get the boat dialed in.
    Jun 2008
    3
    Thanks for the help guys, its deffinately helping me save some money by buying what i need first time, Cheers
