Page 5 of 5 FirstFirst ... 345
Results 121 to 142 of 142
Thread: What is the deal 43MPH still?!?!?!?!?
  1. #121
    Aug 2012
    190
    Quote Originally Posted by dana View Post
    Thanks. I used .150 cable but go for 3/16.
    okay sounds like a plan. i think the boat comes with a 1/4 strut should i sleeve it or replace it?
  2. #122
    Mar 2010
    MA
    3,573
    You can use 1/4 brass stuffing tube with no teflon liner and 3/16 cable, or use Teflon liner with .150 cable
  3. #123
    Aug 2012
    190
    i still have the .187 wire drive too but i think the strut is 1/4. maybe i will but bearings in it?
  4. #124
    Mar 2010
    MA
    3,573
    You can do whatever you like
  5. #125
    Aug 2012
    190
    at this point i better wait for the hull so i know what all i need. thanks again for everyones help.
  6. #126
    Oct 2012
    am
    2
  7. #127
    Oct 2012
    am
    2
    This is my traxxas spartan stock 6cell 2p.Max speed 47.2mph.from greece with love!! You can see more videos www.traxxas spartan by electronin service.
  8. #128
    Aug 2012
    190
    I have not had time to run the boat yet but I think I might get it out on thanksgiving or the weekend but in the mean time I got most all of the marts to start the build on the mean machine. Someone was telling me to go with an M445. The M is just a de-tonged X right? I know they are different hulls but if I am already at a X645 this a heavier boat and all my temps are good. why would I go down?
  9. #129
    Aug 2012
    190
    Okay I finally got out on the lake over the holiday the best run a got was 47.9 that is with the strut up 5MM, the tabs up 4MM at the back, the batteries all the way back. COG 25%. At that point I took the drive line out and put it in the mean machine. I started a new thread on that in the building section. I will post a link shortly. With the stock ESC, motor, and a 215 prop it ran 34 mph. maybe I forgot to bring in the anchor. Any suggestions? I guess I will keep going up on the tabs. But can I go higher on the strut? Here is short clip, I think I hit a fish LOL FYI the ESC stayed dry this time!!
    https://forums.offshoreelectrics.com/...ne-The-Phoenix
  10. #130
    Jul 2012
    Tn
    1,202
    was that your battery that went to the bottom of the lake???
    Im Only Responsible For What I Say Not For What You Understand
  11. #131
    Aug 2012
    190
    no it was my GPS and it actualy floated in the water tight bag, i should have punched it sense all was in tact when i got to it.
  12. #132
    Aug 2012
    Wi
    175
    just read your thread, mine is running 62 mp/h without problems
    setup:
    adjustable stinger strut
    longer rudder (double pickup if possible, longer because it helps to get the chinewalk away)
    cnc billet trim tabs (you need about 3 hours to adjust them if you go the same setup like me, more speed = more pulling to the side ;( )
    upgrade to 3/16 cable
    upgrade motors to 40mm (mine leopard 1800kv 40mm 3,5d)
    better esc: ish 200+ amps
    better prop: prather s225 (with lift)
    2x 3s lipos 8000mah (perfect weight) 50/100c discharge serial plugged completly back in the boat ( get an antispark, after 3 sesions you wont change the bullet connectors any more :p )
    collets and other improved stuff like bigger tubing and cooling
    finish: balance it
    small tuning: reinforced hull with epoxy (back), taking out the stiro in the front of the boat and put some U.P. in it (less weight, better stability of the front, still cant sink), and a thing that gives me 0,3 mph, you wont belive it, put some lack on it, it doesnt get much, but the bit that it gets is perfect to put the back more into the water.
    my hull weights at front -0,3 kilos and back +1,3 then the stock setup, it needs about 1 second to get out of the water, but its very stabil, no chine walk (was my biggest problem before)
    its very expensive to change all this stuff, and you get everytime risky to overheat your setup so be careful, dont instant start him or drive with full throttle all the time, check your temps.
    Zonda 41" Carbon Cat, Motors: 2x 2075KV 3674 Brushless Inrunner, ESC: 2x 200Ish plus, Props: 2x 42mm, 2x 5s 5000Mah 50/100c
  13. #133
    Aug 2012
    Wi
    175
    you dont hitted a fish, thats the chinewalk, everyone loves it on the spartan, hahahaha, did you change something on the turn fins? looks like you go from chinewalk to turnfin and then the boat turns around, if it woud be a fish your boat woud not do such a nice roll
  14. #134
    Aug 2012
    190
    Lol yeah the boat is a pain I see so few having great success like you. If you look at a few of my posts I have has a lot of upgrades on there. With the 4092 1340kv I was up to an X646 I kind of have up after I found how hooked the hull was. If I can get it into the mid 40s o. The stock setup I might try upgrading it again this time going with the higher kv I think swinging that big of a prop just caused more problems.
  15. #135
    Aug 2012
    Wi
    175
    Quote Originally Posted by traeside View Post
    i think to the pops make the most problems on the spartan while driving, a to big prop increase chinewalk or barelrolls, the best is a prather s220 with a 1600kv leopard 4082, a 4092 is not made for 6s, look on the leopard page to see the max amps and lipos
  16. #136
    Sep 2012
    CH
    61
    Hi Guys,
    could anyone tell me what's the difference between an Octura x442 and x642 on T180 ESC with Leopard 1600kv motor.
    I mean, what problems I could have putting the one or another prop.
    Thanks, salute all.
    Niky.
  17. #137
    Aug 2012
    Wi
    175
    Quote Originally Posted by Niky View Post
    Hi Guys,
    Thanks, salute all.
    Niky.
    x442
    Diameter: 1.65"
    Total Pitch: 1.4x1.65=2.310"
    Shaft Size: 3/16"
    x642
    Diameter: 1.65"
    Total Pitch: 1.6x1.65=2.640"
    Shaft Size: 3/16"
    the pitch is bigger on the x642, the question is, what size leo you got, what boat (type/lenght), single/twindrive, lipos, Wind of motor.
    your motor will heat more and pull more amps
  18. #138
    Aug 2012
    190
    Quote Originally Posted by Mecka1990 View Post
    i checked it before i got it and it is 6S max. Steve here recomended it. it has been doing fine for months now.
  19. #139
    Sep 2012
    CH
    61
    HI Mecka 1990;
    I have the Spartan, now planing to buy at OSE Store the T180 ESC + Leopard 1600kv motor.
    My batteries are : - couple of Venom 3s 7500 mah 35c
    - couple of Team Orion 4200 mah 45c
  20. #140
    6,453
    A 4092 certainly will run on 6s, mecka. Not sure where you got your info. And, it will spin a much larger prop than a s220. Unfortunately, the boat won't handle much more prop. (Chinewalk)
  21. #141
    Aug 2012
    190
    you got that right! and like i said some people are making it work but it is not easy and i think that if your hull came hooked like mine did you are going to be fighting a never ending battle. i dropped the drive train in a mean machine and it is much more pleasurable to drive when it stays on the water LOL
  22. #142
    Aug 2012
    190
    HI Mecka 1990;
    You might want to go with the 1800kv it seems alot of people have good luck running the smaller props.
