Okay so I was running 41 on the stock setup with 6S, 3 tabs at 0 right inner -1 strut at +,1 batteries all the way back. Now I have the SeaKing 180, Leopard 4092 1480K and Prather 220. Still could not break 43. I think the hobby king 3S 5000 45C are not holding up. I am getting the low voltage cutting out under hard cornering. I had it set at 3 volt. Now at 2.8 but not tested. I am running on flat to very mild water. All temps at 80-90 degrees. I am going to try the Octura 642 and see what that gets me. With 80% efficiency and 25% slip the 220 should be 48MPH. it looks like it is running wet and start chine walking almost every time I get to WOT.
So unless anyone has a better suggestion I will order some Gen Aces 5300. And just keep going up on the props tell it gets hot.
