Page 1 of 2 12 LastLast
Results 1 to 30 of 37
Thread: "Double Tap" Twin Screw 41'' Fantasm
    Jun 2012
    1,509
    Cool "Double Tap" Twin Screw 41'' Fantasm
    Working on another one...
    41'' Fantasm
    FC 3-16s 300A Twin ESC
    Twin Sirius 1717 / 1580kv Motors
    6-8s SAW
    Feb 2011
    430
    Nice! I absolutely love my Fantasm. Mine is a LV setup but still does 65-70 MPh on 5S. Great handling boats also!
    Jun 2012
    1,509
    Carbon Fiber Installed...
    Jun 2012
    1,509
    Stingers Installed with CF backing plates.....
    Jun 2012
    1,509
    Why...so...Sirius...? 1717/1580kv
    It may not look like it, but it's a tight fit and I don't have the jackets yet....
    Jul 2012
    NH
    105
    Wow I would have thought there would be a bit more room than that. Will be interesting setting up the stuffing tubes. Looking good so far!
    Jan 2011
    PA
    1,141
    Nice, where did you get the motors?
    Jun 2012
    1,509
    Quote Originally Posted by Cooper View Post
    Keith Bradley
    Jun 2012
    1,509
    Quote Originally Posted by JrValente View Post
    It's going to be tricky, I won't be able to put much angle on the motor.
    US
    5,557
    You think you can get them in there with the jackets on????? Bit late now but twin 4092's would have been much easier and just as powerful. If it doesnt fit you can sell those easily and get some 4092's.
    Feb 2011
    430
    Mine has TP 4092's and they fit great.
    Jun 2012
    1,509
    It's a Biggin...
    US
    5,557
    Hopefully yours wont blow up 5 seconds into your run and scorch the inside of your boat......................
    Jun 2012
    1,509
    Where's the optimism? Can't you hope for at least 45 seconds.....give me a chance to get on plane...
    Jun 2012
    1,509
    Rudder mounted with 4 layers of carbon fiber cloth laid up inside the transom....
    US
    5,557
    I'm a fan of big, long rudders with dual pickups
    I get rudders longer than usual, and if they dont work out, then I lop some off, you cant add!! I've only cut two down so far out of 20+ boats, i like 'em long, great control that way in my opinion. I race my Pursuit so its just average length where you need all the help you can get.
    Jul 2010
    3,663
    you cant add.
    I beg to differ sir...
    US
    5,557
    Quote Originally Posted by keithbradley View Post
    OK, fill me in...........
    Feb 2011
    430
    Im diggin the dual pickups. Very nice
    Jul 2010
    3,663
    Just busting your chops.
    I've made them longer before just by TIG welding aluminum bar to them and then finishing them off to the correct shap/size. I realize most people don't have the ability to do that though. Cutting them off is far easier!
    Jun 2012
    1,509
    Installed some hatch bolts...
    Jun 2012
    1,509
    ESC Mount...
    Jun 2012
    1,509
    Shoehorned in...
    Jan 2011
    PA
    1,141
    Looks good so far. Im watching and keeping notes as im planning similar build over winter. Might go cf hull but same motor setup. When you run those on 8s what are you realistically trying for top speed?
    US
    5,557
    Looks good...........................you may have a 70 mph boat on your hands.
    Jun 2012
    1,509
    Motor mounts and tubes in...
    Simple paint. Nothing special..
    Jun 2012
    1,509
    Ready for testing...
    7,631
    That controller looks so good in there I may have to get me a Fantasm.I'm sure my 950kv TP's would do it.
    Sep 2009
    1,535
    what props you got on there ? with two of those torque monsters in the boat you will be able to spin some hefty props... also did you run the bolts for holding down the ESC thru the tunnel ? Looks good... and the dual pickup rudder is the way to go as far as I'm concerned. I've yet to see in hull pickups spray out water like these do.
    Looking forward to seeing it run
    Jun 2012
    1,509
    I have a set of Prop Shop 4518's and 5017's, we'll see how she does...the ESC mount is bolted to another CF plate that is epoxied in place.
