300 burst rated, subed on takeoff.
So, 6 caps series + parallel as shown?
Mildly concerned of damage to esc caps.
Test the onboard caps, in circuit.
All will return same if ok.
If not same, the recommended bank is insufficient.
Enjoy !
Wayne;
Very informative thread, learned heaps, thanks for that !
A question: I've read -someplace I forgot-, that when adding a cap bank that (more) smaller caps were better than (less) bigger ones, assuming they both would add up to the same capacitance.
Had something to do with discharge speed but not sure?
Also does the wiring thickness make a difference at all on short lengths of say 2-1/2" / 6cm?
I found the wires quite thin on my 180 V3 for the cap bank, and thought about changing them, but looking at leads of the caps itself, all these little electron guys will still need to 'squeeze' through those tiny leads right? Your thoughts?
I understand the necessity on longer lengths.
Thanks in advance
P.S. 'Schutte' , Dutch heritage?
The capacitors are flattening the AC ripple current not the DC drive current so, that's how T180 v3 gets away with thin leads. I've used 14G wire before on a hot 6s2p setup and it's just fine.
But.. (don't you love starting replies with that....) I understand part of what you say, the part where the caps are not taking the full current, but now you brought up another question: how can it flatten AC current, shouldn't they be mounted on the output side (AC) -in this case motor leads- as the input is DC right? I thought (and apologies for using layman's terms, otherwise I wouldn't even understand my own typing) that the caps store energy -from-battery- and deliver extra during peak pulses when batteries can not deliver that quick to the esc.
My electronics theory is old but, the basic rule is that capacitors pass DC CURRENT but, block AC CURRENT.
Why block it on the input since you say it is connected to a pure DC source (lipos) ? Well Backemf is the reason I think?!
Thats not the best link for the information. Someone posted the correct explanation in an old thread of BL motor theory.
Basically when any winding is energized (pairs are energized at any given time on our BL motors) it forces the core armature to move until it is de-energized (shut off). When power is disconnected from the winding the magnetic energy field in the coil collapses and this collapse sends a BACKEMF voltage in the other direction back into the esc. This is (I think) is where/when the caps settle that returning ac waveform. This happens at a frequency that you set your esc to like the 8Khz or 16Khz, etc. This is a ac wave in the form of Pulse width modulation PWM, square wave.
I'll take any lambasting for any mistakes in here. I took my best shot. lol...
Dr Wayne as I told a youngster today I learn something new every day. Thanks again mate
Top Gun 2011, "current problem" 88MPH. Top Gun 2014 "Marine One" 99 MPH. bet speed to date 125 MPH
@Viper1 .. seems you missed the meat in sandwich.. read lower half of this post re ac/dc ripple
https://forums.offshoreelectrics.com/...127#post448127
@Ray. Shhhh. .. :) you have confused logic answering Viper1's misunderstanding
The comment more small Vs large is/was mine ( dont remember where)
The T180 micro external cap bank has less joule return than a single 35V470uf used onboard that esc. The extra are fine for high freq ripple clipping, not more.
Leads.. if the caps have high charge/discharge, why starve them with low yield wires ?
Dr. Wayne sums it up again. THIS is a fairly simple version also:
The way capacitors and resistors behave is totally different. While resistors allow a current to flow through them which is proportional to the voltage drop across the resistor, capacitors oppose a change in voltage across them by either drawing in or supplying current as they charge or discharge resp. The flow of current through a capacitor is thus directly proportional to the rate of change of voltage across it.
This is given by the relation, i = C* (de/dt) where de/dt is the instantaneous change in voltage.
As the voltage does not change in the case of DC, de/dt = 0 and the current that is allowed to pass through by the capacitor is 0. For AC voltage the voltage changes in a regular manner. Hence here de/dt is not 0 and a current is allowed to flow through by the capacitor.
@Viper1
This thread discusses purpose, benefit and variants of capacitance buffering/filtering of the DC input to a brushless ESC ( DC->AC 3 phase inverter. )
Capacitance on the output side has merit, but will not be raised in this thread
ps. 'Schutte' is of German heritage.
Thyer, Schutze and Spier are some previous title holders of last remaining male of this bloodline !
AAARgh, must have been reading to quick, missed that part, crystal clear, probably got distracted by the simple drawing above it...simple seems to attract me more
Pretty sure I got it from a Dutch forum, but covered more the esc's in general, forget the 180, I hear you. What I meant was that all the caps are smaller, but added up have same value as bigger uF's, less in quantity. ?
Re the leads; OK bigger is better, but has it benefits to go thicker than the solid wire coming out of the cap itself, when mounting directly against the ESC ?
Thought it sounded vaguely familiar for a 'cheese head'
Factual data on capacitor performance is no mystery, however application in array form is not common knowledge amongst amateur electron gobblers.
Re: many small Vs few large equals same capacitance.
Charge/reply on a small cap is faster than a large.
Many small caps can buffer a ripple more efficiently than fewer large where their response is slower.
Schutte: from a long line of brewers, beer drinkers, engineers and all round good guys.
Thanks Wayne,
In different words that's what I remembered right then, discharge speed or as you called it response time.
I wouldn't have brought it up if I got it from a amateur
With the cheesehead comment I was refering to myself, to be honest, I would't mind the foamie stuff in the ancestry either.
Thanks again mate
Sigh.... sorry, I understand your answer, but I'm afraid I didn't make my question clear enough. I didn't mean using the solid cap leads to connect the bank.
Let's say for example I have a cap bank, connected with e.g. 12 AWG wires to the ESC, does it have benefits to go to thicker, e.g. 10 AWG wires.
The chain is as strong as the weakest link is what I'm thinking, and in this case both the wire diameters far exceed the cap leads. so would it make a difference really?
All assuming this is on short lengths < 8 cm.
My wire examples are exaggerated but both are thicker then the solid cap leads
The T180v3 external cap bank is connected by awg22 wires... very small by comparison the main battery leads.
However, the caps are also very small, and their charge/discharge is low yield.
Larger capbank charge(joule) movement will create a heat dynamic in the wire.
DeltaT in wires of AC is higher than it's DC rms equivalent..
Ive replaced many caps on escs where the cap leads have burned under load.
By provisioning the capbank with larger connect cabling, that temp dynamic is reduced... lower heat, lower resistance, better for all...
emoticons here are good. sigh ? ..try or
burn and learn, mate.
Last edited by drwayne; 02-17-2013 at 05:56 PM. Reason: b;oody keyboard cannot spell
Got it ! Soooo Thick
Replaced the wires to 16 AWG while I had the ESC apart for my 'cooling mod' but still using original caps.
Kept 'm a bit shorter as well.
Thanks for your patience !
If ever we meet face2face, Im rarely as cool or patient as here !
Saw the flyboy toys, nice.
Best of luck with boats.
DocW
WOW!
my hopes are high for my T180 in my TP powered PMono now reading through this thread
I was unable to finish all six laps as I could only finish 5 1/2, now it may just be bad caps
Hey Doc,
Hows this info http://www.niccomp.com/help/ESR-Ripp...age-032012.pdf
Thanks Mike
Do It Like You Mean It .....or Don't Bother
This is a pic of what happened to my cap bank. I did shrink wrap the bank but, did not insulate the bare soldered leads.
Even if I had insulated the leads, the wire I used to connect them to the SF200 was too thin as well as you can see.
The boat runs dry so it wasn't an abundance of moisture that did it, more of an arc possibly from the AC but, I'm guessing at this point.
Anyway, thicker wire is better, closer to the esc is also better. At least no magic smoke, the driver Fets blew.
Hiya
The main part of your quoted link appropriate to our use is the cap application to automotive audio power rails.
Although for my 12S setup..I didnt find any Sub-amplifier capacitor boost bank capable of 40k 50V 300A !
We are at an extreme of power demands not catered by any the 'domestic' boom box fraternity...
The way you have soldered the caps, forces that last cap's leads to support the feed/discharge from the others.. this doesnt work well as it will likely burn ( see your pic )
Use a basic plain circuit (insulating) board to support your caps, and run the larger connection cable across the base of all the appropriate leads emanating from the caps.
Expect your cap bank to demand/supply the same ( or greater) power as supplied by your power source(batteries)
Logically if your battery/esc uses X-AWG cables..that is the same size required to/from your buffered power source/array ( cap bank )
A quality cap bank will emit a pulse 8x larger than the battery if you short the leads.. so why diddle with small cables when there is such a large discharge potential ?
Note of interest: it has been observed if my safety loop disconnects.. I have another 3 seconds on water run time before the cap bank is depleted and power stops.
3 seconds of 'full' power.. so please dont expect servo sized wires to support that power flow !
Pfft zap :
For those building their own cap banks. Just cut it shorter to match the number of caps you want to use.
http://fightercatracing.com/index.ph...emart&Itemid=1
Head to RadioShack, Tandy, DickSmith, Force, Jaycar, RSI, Fallands, or whatever your country has in the way of electronics super stores and grab a piece of plain predrilled circuit board... 2 or 2.5mm spacing ..
The worst Ive seen was $3 for 4"x2"(100x50) !
The FC jobs are nice, but +$6 for their embossed name on a Chinese product? tsk tsk
I like the substantial + and - buses on the PCB. It keeps it nice and clean. I'll spend close to $3 on the heavy awg wire to join the caps together and it won't look nearly as nice..
