cool thanks
cool thanks
Random,
Here is a rebuilt of a good old proboat Blackjack 26 hitting +70mph.
http://www.youtube.com/watch?v=m3wAk...eature=related
I never got over 3/4 throttle !!!
Looks fast, but completely out of control. Nowhere near trimmed out or stable
almost got the bug worked out! Now I need good water
Post some vid when you get that sucker running full throttle -)
Lol, my genesis looks like that blackjack in the vid!, when i turn up the speed to 1.5x speed
Thats a x645 the motor and esc are running at 91*F can i go with a BIGGER prop?
Hope you have a better place to run! Seems kinda pointless when you can't pull the trigger for more than 3 seconds.
Would love to see it run where you can open it up and see what it really does!
Be interesting to see how long the hull survives at that speed.
The hull is bullet proof 5000 psi epoxy with steel re-enforced with grate stuff foam its like a rock lol And i run my bass boat just have not had it in the water this was just a looksee!!!
yep you cant see a lot of it i put foam everywhere!
5000 PSI Epoxy? hahhaaah awesome :D
if its just been enforced with foam you can just say so dood :P
Thats a sick boat there Random...............sounds mean and spooky in the vid with the echos. Are you running two 4s packs or one? I'm asking cuz thats ALOT of prop for a T180 to handle with a 4082 2200kv...............they like to premature LVC as most know. I bet on a long stretch your boat would gps at 58-60 mph..............nice ride!!
Lol I cut 5 strips of 1/8 inch stainless steel one runs uP the middle 4 up front epoxy them down then did the whole bottom with a good layer of it then the foam !! Thanks!!!.....
I run 1 4s And the LVT cuts off at about 60% of battery
You can lower the LVC to 3.0v, or 2.8v for more runtime.
Will that hurt the battery's ? Or is it just the esc going nuts?
The T180's quite often wont allow you to use 80-90% of your pack, they LVC early, especially with a 1p setup like yours. I went to a 2p in my Pursuit and it stopped happening. Setiing it at 2.8v is not recommended, but I do it and have had no issues with my batts, 3.0v and you're fine for sure.
That is one scarry handling boat . Looks like when you touch the rudder wheel you have to be ready for it to go any where . It's an accident wating to happen . A boat at 55 or 60 that's almost out of control is dangerous .
That is the video that pushed me over to fast electrics! I ditched the idea of resurrecting my old Prather Deep Vee 31' Outboard after coming across this video. The weekend before I had my boat running and I broke a driveshaft, plus I never did get a full tank of fuel run on it. I started that project back in 1993. Electric power is awesome.
Sobie2
just how fast is this boat ever gps checked this boat ???
Im Only Responsible For What I Say Not For What You Understand
