OK I have a revolt 30 with a 4082 an a seaking 180A esc i run 4s and 6s what prop will put me around 70mph so i can run with my bass boat im runing a grim racer 42-66 now and its not quit there thanks for the help if u can
2200kv sorry
I would think an x642 would get you close, but you're running on thin ice with your setup.
Also, you better reinforce the hull. A wipeout at those speeds could be catastrophic
its reinforce with steal and foom and how would u get it off thin ice what do i need
Is'ent a 2200kv motor only good for 4s. @ 5S your pushing 40.700 rpms boom goes the motor?
A 1200kv - 1600kv motor would handle 6s.
look for the voltage chart in here some where.
That hull wont be stable at 70.................looking for trouble.
I agree, the revolt is limited by hull design, not power. 70 mph is just not gonna happen with any good results with this hull. Also 6s on 2200kv Leo won't last long. You might be able to do this with a better quality motor such as Neu but even then you should limit run times.
it saying 22v max
What you need is a hull capable of 70 mph. Then an appropriate motor/ prop combo. There are several combos that could do it, but you need to decide what's within your budget....
so stay with 4s gotcha what speeds am i looking at with the biggest prop?
money not a problem
Well with an m445 or x642 you may get between 50-60mph...
ok i see thanks
If money is no issue, leave you're revolt alone and build a boat that can handle the speed and put a Neu or castle motor in it.
what mono will do 70+
Honestly, I haven't gotten to 70 yet. That's damn fast... So I really can't say, but I'm sure someone will chime in. Or start a new thread on the subject. -)
If you're not limited to monos, an aeromarine mean machine or sprintcat are capable
im going to build one but the revolt is to beat on!
dont really like cats ive been looking just dont know whats all out there
Random,
Here is a stock Revolt running a grimracer L45x68 prop.
http://www.youtube.com/watch?v=M9q0WTdU8mo
I am personally not looking for more than higher 40's on my Revolt. If I ever decide to go faster I will build a new boat from scratch and select the appropriate hull that can take the speed.
i had gps my revolt at 44mph stock with m445 back cut inside trims just about level with the hull
Box stock Re Volt and prop that it came with it 44.7 mph EagleTree. You need a different boat/motor/prop to do what you want.
READ TOP OF PAGE !!! Leo 4082 2200kv seaking 180a ESC x646 !!!!!!
<iframe width="560" height="315" src="http://www.youtube.com/embed/U5d3FZViec8" frameborder="0" allowfullscreen></iframe>
[XX]U5d3FZViec8[/XX]
You tryin to post this??????? Gonzo power you have there............get it on some glass and run wide open, she what she can do!! I say high 50's.
