Results 1 to 2 of 2
Thread: impulse hull
    Jul 2012
    Ok
    160
    Default impulse hull
    just purchased a used impulse. when i opened the box and pulled it out it looks like theres a problem with the bottom hull near the front.
    there is a concaved spot where the second strake starts and runs to where the hull no longer angles down and its on both sides.
    is this normal or should i be concerned. could i get a few side shots and bottom shots from a couple of u so i can compare? thanks Greg
    58" Venom Segad-48" Prather Deep Vee-41" Dumas 1/8 Hydro-34" Saga C1-32" Venom KOS P1-31" Pro Boat Impulse V1
    Aug 2010
    wi
    1,461
    pictures would help
