Page 2 of 2 FirstFirst 12
Results 31 to 40 of 40
Thread: My Revolt 30 - "Bold Skull"
  1. #31
    Jul 2012
    480
    Quote Originally Posted by dshuld View Post
    I do t really want to either. Theres a small pond a few blocks from my apartment in gulfport on 58th st. But i havent seen anyone put a boat in so im not sure if anyone would say anything to me or not.
    I went thru that predicament too before I started boating on the pond near my house and one day I just did. I figure there is always someone that will say something but until that day I'll keep enjoying it
  2. #32
    Jul 2012
    480
    Hello Gang,
    My Revolt is back on the water and running better than ever. I am pleased with AQ fix to the stuffing tube getting loose; not pretty but it does not move now. Here is the pic of the fix:
  3. #33
    May 2012
    940
    Quote Originally Posted by gyrotron View Post
    Hello Gang,
    Crowd goes wild!!!
    Glad your back up and having fun.
    Mike
  4. #34
    Jul 2012
    480
    Quote Originally Posted by Mike Caruso View Post
    Crowd goes wild!!!
    Mike
    Yes Mike, I am having a ball with this boat! Acouple of things I did lately:
    • Diverted the water intake coming from the rudder pick up to the motor cooling jacket and the Esc separately.
    • Added a water outlet to port of the boat and a transom fitting. The transom fitting has a dual function; it serves as a water outlet for the ESC and as a water intake for cleaning the served water out of the cooling system with my mini hose.
    • Replaced stock Dean connectors with EC5 (Deans melted yesterday and boat almost cought fire)
      Currently Testing Octura X440 /3
    This boat definetly grows on you.
  5. #35
    May 2012
    940
    This boat definetly grows on you. I’ll post some pictures tomorrow.
    You said it!
  6. #36
    Jul 2012
    5
    With my strut pushed up carefully about 2mm, upgraded flex shaft and an M545 my silver Revolt is driving on the prop almost exclusively in the straights. I had to drop the fins and straighten them out or the once stable thoroughbred, wanted to slap on its side violently in the turn! Now it is still decelerating into the turn but WOT just at the crest and blasts out into the straight. My favorite boat.
  7. #37
    May 2012
    940
    2nd that.
  8. #38
    Mar 2010
    MA
    3,573
    y splitters are terrible. get rid of it
  9. #39
    1,453
    hey reading some of ur earlier posts about places to run the is a electric boat club in sarasota with a few guys on here that play there-http://www.wfmbc.com/
  10. #40
    Jul 2012
    480
    Quote Originally Posted by dana View Post
    Dana,
    I already did that last week. I noticed temps were going up and I double checked on the "path of least resistance" concept and I discovered I was basically dividing the water flow in two halvs and equaly reducing the velocity of the amount of water going to the motor and ESC. You change you learn... you learn you change!
