Hi,
Here are some pictures of my current Revolt 30 setup. Here is what I've done to it:
1- Added the bullet nut on the prop (used enough blue loctite). Stock prop for now, planning on upgrading to an oct-x642 and Grimracer L45x68 lifter later on.
2- Upgraded to the Kintecracing propeller shaft and stuffing tube
3- Elongated water inlet
4- Installed M6 aluminum water outlet
5- Installed mock up exhaust pipes and red tribal skull decal on hatch
6- Moved turn fins up halfway and increased angle to the back
7- Gave 2 degrees negative to the trim tabs
8- Used 4s 5800Mah 14.8v single battery setup located all the way to the back of the battery tray.
Next upgrade will be installing a thrust bearing and new props.
Running great up to date, chine walk reduced to a minimum. I am very happy with my Revolt!
