Results 1 to 18 of 18
Thread: A Simple and Reliable 2.4GHz Radio?
    Aug 2007
    MA
    281
    Default A Simple and Reliable 2.4GHz Radio?
    What is a simple and reliable 2.4 GHz radio that has steering trim? I haven't been running FE boats for about 4 years at which time these microwave band radios were just coming into the market. I am trying to get back into the hobby, and convert my 75MHz fleet. I tried the Tactic radio on my UL-1 and it's very glitchy - it takes 5 minutes to initialize the motor, even after adjusting for the throttle trim. Is there another radio that every likes and is readily available?
    Mean Machine Cat: 9XL, 4S2P, CC120, M545 (50mph) -- DF22 Hydro: 8L, 3S1P/4500, CC120, x637 (49mph) -- M-1 SuperCat: 1521/1Y, 6S2P, CC240, x447 (61mph) -- SV27 Mono: stock setup, 14-cell/4200, x642 (42mph) -- Micro Scat Cat: 28-3600, 3S1P/2100, Turnigy 60, x430 (41mph)
    Jun 2012
    MA
    1,876
    Tactic needs throttle channel reversed and throttle trim all the way up.
    Tactic is the simplest best radio for boats IMO
    Nov 2010
    OR
    2,493
    I have been using a flysky gt3 for over a year and had no issues.
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
    May 2012
    36
    I have a spektrum dx2-s and it is great but on the expensive side. I also have been running the HK gt-2 system and have no complaints as of yet. Small reciever size and low price make the HK radio my favorite.
    Jun 2008
    OH
    2,345
    Im using the fancier flysky gt3 radio on multiple receivers.
    The unit is $40 for the radio/receiver. One radio will allow like 8 or 10 (cant remember off hand) models programed/saved.
    If you want REAL cheap the Hobby King 2.4 can be had for $20 in the USA warehouse. Note HK receivers and Flysky receivers are the same and can be used with either radio.
    Jun 2012
    MA
    1,876
    I also use the flysky gt3. Great radio. But not as simple as tactic to set up IMO. I figure you have the tactic, use it.
    Jun 2012
    145
    Quote Originally Posted by Basstronics View Post
    HK is always out of stock in both the US and Global warehouse of the GT2. I got Aaron to start carrying it. A little higher, but no shipping, and of course, the shipping time from China:
    http://www.banggood.com/Wholesale-Fs...t-p-48557.html
    Aug 2007
    MA
    281
    Thanks guys! I'll keep the Tactic and purchase another Flysky GT3/2 just to try out. WOW! Radios have gotten cheaper - can't go wrong with $28. I wonder, if I can still use my Hitec HS 545BB servos with a 2.4GHz radio?...
    Jun 2008
    OH
    2,345
    Aug 2007
    MA
    281
    Thanks Bass!
    Jun 2008
    OH
    2,345
    One BIG word of caution. These dont like to get wet. If you get the receiver wet its basically junk.
    Corrosion X is a MUST.
    130
    I also bought a FlySky GT3B to use with my smaller boats and rock crawlers. Once I had the radio for a while I found that it worked very well having as much range as my Futaba 4PL and felt very much like the Futaba. The receivers are only $7.40 ea. I recently upgraded the firmware on the GT3B and it now has more features than my 4PL.
    - 3-8 channels
    - 60 model memory
    - Sub trims
    - More trim value (up to 99)
    - copy models
    - fixed expo
    - Model reset
    - Channel speed
    - 4WS Mixing
    - Dual ESC Mixing
    - Dual ESC steering
    - Multi Positions Switches (Up to 8 True positions out of a single push button)
    - Key Mapping (any key can control any channel in many different ways)
    - Calibration Menu
    - Key Test Menu
    - Backlight on time
    - Inactivity Alarm
    - Adjustable Low volatge warning
    - Adjustable Maximum End Points (Up to 200% i think)
    - Adjustable dead zone for steering and throttle
    - Turn keep beeps on/off
    - Adjustable long press delay
    The Trim and d/r keys can do this
    - nothing, it is possible to assign each button individually as key
    - trim of channel 1/2
    - dualrate of steering/forward/back
    - expo of steering/forward/back
    - change channel "n" value in range -100...100
    - subtrim of channel "n"
    - 4 wheel steering mix -100...100%
    - DIG throttle mix -100...100%
    - Multi-POsition, switches position up/down
    - steering speed turn 1...100%
    - steering speed return 1...100%
    They Can be setup to act like this
    - momentary, hold left/right trim key to get end values,
    when nothing pressed, servo is at centre
    - no long keys, long press is the same as short press
    - autorepeat is on
    - long press of one of trim keys will reset to
    centre/reset value
    - long press of trim key will set to coresponding end value
    And they can have an adjustable step rate, opposite click reset, reversed, etc.
    And the Keys (ch 3 button, back button, end button, and the trims if set individually)
    - nothing
    - switch channel "n" value from one end value to opposite end
    value.
    - reset value of channel "n" to centre
    - switch crab (CRB) no-crab (NOC) for 4 wheel steering
    - switch DIG mix between -100 and 100 (more useable when using
    return to previous val key setting)
    - Multi-POsition, switches position up (at END back to 1.)
    - Multi-Position Reset, switches position to first one
    __________________
    Aug 2007
    MA
    281
    Thanks Fast Guy for the detailed list of upgrades. How do you upgrade the firmware?
    130
    Quote Originally Posted by 10gauge View Post
    flysky-gt3b-transmitter upgrade
    Check out post #3000
    gt3b-hack-question-answer-thread
    I did the firmware upgrade myself but it takes some soldering and computer know how. There are many that offer the service for a small fee in the USA and Canada.
    Jun 2012
    MA
    1,876
    What happened to simple? How many useless features do you need for an Rc boat?
    Aug 2007
    MA
    281
    Quote Originally Posted by Heaving Earth View Post
    Curiousity mostly. I didn't realize these units were that versatile. The only frills I welcome is steering trim, otherwise I am sticking to simplicity.
    May 2012
    23
    I also use the FSGT-3B, and am in the process of getting more receivers to use this for my trucks as well. For under $10 a receiver you can't go wrong.
    I may try to dunk one in plasticote to waterproof, as there is not much room in my hull for a box / o-ring.
    For the price, I believe it has a nice feel to it, in my opinion. Only one small compaint - if you use the trim arrows instead of navigating through the menu, you have to push the round button in to get out of the adjust mode. No real biggie, just something that I notived when I went to digital trim versus the old knob
    130
    The GT3B works just fine in it's stock form. For $40.00 it is well worth a look. I flashed my firmware to run 4WS and winches in my scale crawler and to add a count down timer for running my boats.
