Page 1 of 2 12 LastLast
Results 1 to 30 of 51
Thread: Tenschock Electra Big block
    Jan 2014
    GF
    31
    Default Tenschock Electra Big block
    Hi Guys !
    Sorry for my little english but i'm french :lowdown:
    I open this post to introduce my Electra 95 in progress . My goal is to break the barrier of 100mH with this boat …
    My setup is as follows:
    - 2 X leopard serie 4082 2200kv
    - 2 X Truginy Marine 180A
    - 2 X Turnigy nano-tech 4000mah 6S 45~90C Lipo Pack ;
    - 2 X Drives MHZ Mystic 1114
    Here are some pictures of the equipment already received :
    I already have a little progress in strengthening the hull and rudder assembly.
    Tomorrow I attack the stingers and I will make some nice photos !
    have a good night !
    Ga
    5,267
    Welcome to OSE Yoann!
    Aug 2009
    tx
    3,534
    Watching
    Aug 2011
    UK
    487
    I personally wouldn't use those mounts in the sponsons as you won't be able to get to the outside fixings once they are epoxied in place
    Feb 2008
    GB
    2,727
    Out of curiosity, what is in the little black bottle with the long white lid on it from MHZ?
    I know what you mean Matt they are FAR from ideal, but if he sets the front plate to the correct angle with threadlock on the screws before fitting and uses short hex machine screws rather than allen screws one the rear clamp, then he may be able to get a slim open ended spanner down the sides and get them on and off that way, a right PITA, but probably possible (check it out before gluing in).
    Will the motors be watercooled? As it is a SAW build maybe not (or just the mounts which aren't very effective, if you were relying on just those I would treat them as if they were not cooled at all), if the motors are not getting jackets he can swap the mounts round so the screws for the rear clamps are accessible, set both front and rear to the correct angle/height, threadlock the screws before gluing in, and easily slide the motor in and out from the back.
    Feb 2008
    Gr
    168
    I have the same boat with almost same setup (with tp 4050l 2350kv motors).
    Its a great hull but you need to reenforce it as good as you can. It's very important this point of your project.
    Here is my last test on 5s https://www.youtube.com/watch?v=PjNE...re=c4-overview
    and here is the building progress https://forums.offshoreelectrics.com/...hlight=electra
    Good Luck
    Tenshock Electra Twin
    Vortex Hydro 24'
    Jan 2014
    GF
    31
    In the black bottle is a "loctite" 648 for paste the flex
    yes it is the motors be water-cooled
    http://www.ebay.com/itm/2200kv-Leopa...:X:RTQ:US:1123
    Jan 2014
    GF
    31
    Quote Originally Posted by xkos View Post
    Good Luck
    very nice boat my friend ! and thank for your tips !
    Jan 2014
    GF
    31
    WORK IN PROGRESS …
    next step to strengthen the hull !!!
    Jan 2014
    GF
    31
    work work work …
    Jan 2014
    GF
    31
    :rocking: always work work work
    Jan 2014
    GF
    31
    coming soon ...
    ON
    9,400
    Did you use leftover gel coat dust to colour your epoxy? NIce job!
    Jan 2014
    GF
    31
    Thanks dude !
    No , I use a dye to color my epoxy based collages .it is not a dye to the resin, but it works very well
    Dec 2011
    NY
    1,447
    nice job man. just wondering how is the hull layup, is it pretty stiff stock or are reinforcements necessary to run with confidence.
  16. #16
    Jan 2014
    GF
    31
    I currently work on strengthening the hull
  17. #17
    Sep 2013
    it
    3
    Ciao,le lipo 6s 4000mah sono sottodimensionate per i 4082,nel mio jolly con 2 4074 uso le 5000 e son piccole,ora son passato alle 6400.I supporti motore non vanno bene,una volta incollati non li levi piu'.
  18. #18
    Jan 2014
    GF
    31
    the boat is finish !
    very bad weather for the first test ; more than 38mph wind that day
    and problem focused radio
    movie link first session :
    first step 100mph ...
  19. #19
    Jul 2011
    ID
    1,292
    Cool
    Now that is a sick boat, geat Job. I love the paint job, its pool retty trick
  20. #20
    Jan 2014
    GF
    31
    thanks dude !
  21. #21
    Jan 2009
    GR
    162
    nice boat.130km... wich props?
    H&M Intruder S twin Leopard 36/74/3270 @ 3S-HIFEI 200A
    MHZ mystic 114-TP4050 5D-HIFEI 240A hv ESC- @ 2 x 5S
    BANDIT S"love boat" LEHNER POWERED.. RCFASTBOATS.GR MINI COOPER CAT
  22. #22
    Jan 2014
    GF
    31
    X447 sharpened
  23. #23
    May 2012
    940
    Great build perfect!
    Do It Like You Mean It .....or Don't Bother
  24. #24
    Jul 2011
    ID
    1,292
    Cool
    Quote Originally Posted by Mike Caruso View Post
    I agree Mike
    I love the paint job, that's pretty sweet. The build is straight forward, simply & effective ,needless to say I like it. Every time I see a twinn build it makes me want to twin my mean machine sooner than later. I've already got 1 stinger, a 2030kv motor, a 2350kv motor, a pair of counterotating x447's & a nice pair of 4s & 5s packs. A few more odds & ends and i'll be in business
  25. #25
    Feb 2008
    Gr
    168
    My Electra hits 125-130kmh with 5s and 4518/3. I haven't try 6s packs yet but I believe 140+ will be easy. Try to play t180s with no cut off. Great job good luck
    Vortex Hydro 24'
  26. #26
    Jan 2014
    GF
    31
    thank you friends!
    new test this weekend, I think easily exceed 150km/h ;
  27. #27
    Jan 2014
    GF
    31
    second session ,"bois diable" Kourou 97310 french Guiana
  28. #28
    Mar 2011
    BC
    7,629
    Good work. Thumbs up buddy.
  29. #29
    Jan 2014
    GF
    31
    thanks !!!
  30. #30
    Jul 2012
    SP
    975
    great run ....felicitations! Gilles
    GO FAST AND TURN RIGHT !
    www.grsboats.com.br
