Results 1 to 7 of 7
Thread: 4s battery on stock motor
    Jul 2012
    CA
    5
    Default 4s battery on stock motor
    My stock esc died just after 5 packs on 3s. I replaced the stock esc with a 30a esc that can handle 4s. Would the stock motor be able to handle the 4s?
    Aug 2010
    wi
    1,460
    might be to many rpms for the motor
    Jul 2012
    CA
    5
    Ran a 4s 850 mah batt today. It so fast compared to the 3s. It was almost boring to run 3s. Only ran it for 3 mins. Motor temp after the run was 95f and esc was around 90f. I only ran the 4s once and 3s another 7 runs back to back to torture test the esc and motor.
    Jul 2012
    KY
    11
    What ESC did you go with?
    Jul 2012
    CA
    5
    I'm using a modified 30a Hobbywing aircraft esc. Basically I took the cooling pipe off the original esc and jb weld it onto the hobbywing and re-shrink it. I also jb weld the cooling pipe that is ziptied on the motormount. Almost forgot to mention that I silicone sealed the esc.
    Jul 2012
    KY
    11
    Minizoom how has your 30a Hobby Wing esc been holding up on 4s? Any programing or over heating issues?
    Jul 2012
    CA
    5
    Quote Originally Posted by kyrzrone View Post
    No issues so far. The highest temp I got from the esc is 97f. The only problem I've had was all three hobbyking 4s batt puffed. I''m not sure if that due to age though. My run time on 4s 850mah is only 2 mins then slows down.
