Results 1 to 4 of 4
Thread: Upgrading to a Seaking 180 ESC...
    May 2009
    376
    Default Upgrading to a Seaking 180 ESC...
    Well i think the time has come to upgrade to a Seaking 180 ESC in my Spartan. Few questions, will the 180 work good with the stock Traxxas 2.4 radio/reciever, what is the size of the stock Castle motor bullet connectors (4mm?? they aren't 5.5, i tried them), and what is the timming for the Castle motor? Thanks
    Feb 2011
    AB
    775
    Can't help you with the motor questions, I don't run the stock castle motor. But yes, the Traxaas radio system will work fine with 180.
    Kevin
    Apr 2015
    40
    I no its been awhile but how did you do with the new 180 on the spartan? I am about to order one and just would love to know all the things I might need to know. Thx
    Oct 2013
    1,060
    When you get it make sure you get a program card for it as well. The V2 was prone to early Low Voltage Cut off and water issues. The V3 seems good, I would run a BEC on it though to reduce temps.
    I would stay away from 6s....
