Not sure if this was design that way.
Can you guys check your boats and tell me if your rudder is offset the same way mine is?
Robert
Robert
DJI Drone Pilot
Canada
Hmmm, looks like another project over the winter....
It was mounted that way. Will this create problem on the water?
Hope not much....
DJI Drone Pilot
Canada
Mine is not like that.
Mr Grimracer, what is your take on this please?
DJI Drone Pilot
Canada
Grand River Marine Modellers
Can't you just loosen the bolts and straighten it out? Looks like fairly normal "mounting slop" to me... If the holes are clearanced correctly, and assuming the holes in the transom are drilled correctly, that could be simply a matter of loosening the bolts and moving the rudder back to vertical.
Darin E. Jordan - Renton, WA
Bolts and rudder holes are drilled tight, no room to move.
From what I see after removing the rudder the holes are not drilled properly. They out of line so I will need to fill one up with epoxy, paint and drill again to fix it.
I will only do the buttom one to be able to move it little closer to the prop shaft.
Little that I have to do this with new boat.... Why mine???
DJI Drone Pilot
Canada
Well... in lieu of getting a replacement, I'd probably opt to just slot the holes in the mounting bracket or open them up so it can be rotated back vertical. Not ideal, but in the end, the important part is for the rudder to be vertical.... You'll want to use some larger diameter washers to cover up the open up'd holes...
Thank You Darin...
Easier and quicker I guess...
DJI Drone Pilot
Canada
Or you could just do the simple "bend it back in shape" protocall......
Bracket is not bent Doby, holes are drilled wrong...
I will not bent the bracket. I will drill open one of the holes
on the bracket to be able to move it a little...
DJI Drone Pilot
Canada
Rudder fixed, thanks Darin.
DJI Drone Pilot
Canada
Hey Darin,
You got it fixed great! Let us know how it runs when you get into the water. I have not run mine yet it is all apart right now, hope to run next weekend.
MC
It is not noarmal, sorry about that!
I would also file or adjust the holes in the transom.
BTY, I have run rudders up to 11deg angled with some secuess. But the revolt runs best with the rudder stright.
Grimracer
