Results 1 to 3 of 3
Thread: Strut height
    7,631
    Default Strut height
    Hey guys,I am putting together a PB Miss Bud (same as Elam)and am going to set a new stuffing tube with a exterior strut.What I need to know is roughly the height of the strut so I can epoxy my tube in.Thanks in advance, Shawn
    So to add;this is a partially converted hull that I got.Here is what I have so far
    The motor is a Hacker B50 6XL 2630kv
    It came with the rudder and I got this strut for it
    And it had a broken tube in it and the old setup was removed
    So if you guys can help me set my strut height so that I don't end up putting too much pressure on it later with adjustments it would be appreciated.Thanks again
    Nov 2010
    OR
    2,493
    Did you ever get the strut figured out if not let me know and I can tell you what mine is set at.
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
    7,631
    I got it running fairly well.Changed to a 1512 2650 motor,set the strut centerline at 5/8 from the bottom where the strut is not the rear pads.This isn't a very good vid to see how it runs but http://www.youtube.com/watch?v=guG4R...&feature=g-upl
