Just recently I bought a Spektrum SR200 receiver for my SV27 & my electronics are stock except a lipo cutoff. When I first plugged in the batteries the first beep came on then I pulled the trigger then the 3 beeps came on after & everything was working ok for the first minute. I unplugged the batteries then plugged them back in to check it again everything was fine then all of a sudden the motor stopped working & all it was doing was sounding this constant "beep" from the ESC I unplugged the batts then plugged them in again & it would keep giving me this constant beep noise. I would push the trigger forward then it would beep once but then the motor would get no throttle & sometimes it would suddenly go full throttle without me pulling the trigger! Now does this have to do with the kind of reciever I'm using or is there something wrong with the ESC? Everything is connected properly & the steering servo is working fine now I'm just wondering if this is a reciever or ESC problem? Your help & advise would be appreciated thank you.
