Page 1 of 2 12 LastLast
Results 1 to 30 of 50
Thread: Transmitter / Reciever Upgrade...Help Needed...2.4GHz - Best Range for the Buck?
    Oct 2011
    OH
    184
    Default Transmitter / Reciever Upgrade...Help Needed...2.4GHz - Best Range for the Buck?
    I'm in the process of upgrading my TX and RX for a new build. I currently have long distance range blackouts with a properly set up 2.4 GHz Spektrum MR200 and Proboat "branded" Spektrum transmitter.
    My lake is large and I sometimes I run my boats out very far. I'm wondering if anyone has a recommendation for the best range for the buck in a 2.4 TX/RX.
    I've spoken with the Spectrum guys several times at Horizon and have been told that all of their surface model transmitters used with the marine receivers (DSM2) will have about the same range I currently have. They actually recommended to switch to a Traxxas system (boo) or air transmitter, which I'm highly reluctant to do. I want to stick with 2 channel pistol grip TX and don't want or need telemetry.
    Any help/recommendations would be much appreciated.
    Thanks in advance!
    Chris
    May 2012
    NE
    9
    I feel that any of the Futaba 2.4 radios would serve you well. I have been running a 2.4 module in a 3PK for several years on some very large ponds with the atennas in the radio box with no issues. Hope this helps, Justin
    Wa
    5,905
    What does "properly setup" mean to you?
    Quote Originally Posted by c_michael_72 View Post
    Thanks in advance!
    Chris
    Billy Graham
    Oct 2011
    OH
    184
    Properly set up to me means:
    - I have the receiver and ESC (CC 240 Hydra Ice) as far away as possible.
    - There are no heat sources or power wires near the receiver or antenna wires.
    - The receiver is isolated from vibrations via high quality servo tape.
    - The horizontal and vertical receiver antennas are very close to 90 degrees apart.
    - The horizontal antenna is not near the aluminum hull reinforcements in my boat.
    - The vertical antenna is straight and as far up in the antenna tube as possible.
    - All my connectors are maintained and corrosion free.
    What am I forgetting? Maybe programming the proper output voltage from the BEC?
    Wa
    5,905
    sure you don't possibly have a break in your antenna wire? Have you tried another reciever? What kind of range are we talking here?
    Billy Graham
    Cool
    Is the ProBoat 2.4 transmitter actually the equivalent of the Spektrum DX2? Some earlier Spectrum transmitters were not completely compatible with the true marine receivers. You may be able to just buy a new Spektrum-branded transmitter...or not.
    May 2012
    ID
    53
    Thumbs up
    This is what I got for 60 bones :)
    http://www.rc-fans88.com/goods.php?id=553 , I love it! made my futaba enter the closet zone! and for $60.00? Psshhhh real hard decision there for the price,,,,, Not!
    Thank you much!
    Hydropilot
    WA
    8,335
    WHAT?? I don't know who you are talking to, but there is NO WAY I'd pick a Traxxas system over a real Spektrum setup.
    The MR200 is an excellent RX... I'm not sure about the guts of the Pro Boat Branded TX that is compatible with it, but I do believe it's a true Spektrum system. You do NOT want to use the true surface RXs, however, as they will NOT have the range you are looking for.
    Have you RUN this out there yet?? You didn't mention if you've already tried this system or not??
    I can run my boats out to where I can't see them any longer, well out over 1,000 yards and they always come back. IF you setup the system correctly and bind it with the failsafe positions set (throttle neutral, steering neutral, etc.), then IF you run out of range, the boat should simply stop. When a Spektrum system loses signal, it falls back to these fail-safe settings.
    Darin E. Jordan - Renton, WA
    Dec 2009
    on
    2,187
    I use both marine RX's with a dx2s and can run my boats out so far I can't tell what direction they are going.
    I have a PB tx that I've never tried, next time out I should test it at least.
    Some of the guys around here are using the 3 channel Hobbypartz radios with good success.
    Oct 2011
    OH
    184
    Well hello Mr. Jordan. Glad to hear you chime in! I agree with you on NOT selecting Traxxas over Specktrum. But literally just 5 minutes ago, I spoke with a SECOND technical rep. (option 4) at Horizon Hobby and he told me the same thing: basically that Traxxas systems had a reputation for longer range...don't shoot the messenger : ). He did however say if it was him, he’d try a true branded Spektrum transmitter and set the voltage of my BEC to 6.0 instead of 5.0 where it’s previously been ran.
    When you ask: “Have you RUN this out there yet?” What exactly what you’re asking?
    Yes, I’ve ran the setup…(your design btw ) and yes, I’ve range tested it on both water and land. I just seem to just run out of distance before I’d like to. You can go pretty far pretty quick when your kicking up a sizable rooster tail at 63 mph in highly modified, and admittedly overpowered/rev’d Impulse 31 : )
    As for the actual distance, I’m a poor judge. I’d have to do another dry range test and measure the distance with an odometer. I can tell you that you can barely see the boat when I hear it stop. I know about where I’m going to run out of range on the lake so I just don’t exceed that perimeter. Occasionally, when running parallel to my range boundary, I get too close and will experience signal loss and the system goes to its neutral positions for a second or two before generally coasting back into range.
    Oct 2011
    OH
    184
    I'm sure, unless it came from the factory that way. I did try a second new MR200 with the same results. Not sure about the exact range but I can barely see the boat.
    6,453
    Yup. FlySky Gt3C. Easily the best bang for your buck. This new model is much easier to read in direct sunlight, plus it's equipped with a lipo battery which can charge via usb. I also own the older Gt3B, which is an excellent radio. Recievers are cheap as dirt for it as well.
    Wa
    5,905
    So if you can barely see the boat that says to me it is very difficult to control it since you have a hard time seeing it so why do you want to go out further? Doesn't seem like you have a range issue to me.
    Billy Graham
    Oct 2011
    OH
    184
    Yeah, I can barely see the boat; however, it's relatively easy to see the massive wall of white water behind the boat. Seeing the rooster tail is all I’ve needed thus far to keep track of position/orientation/direction and maintain control.
    Why do I want to go further??? That's kind of a silly question. Much like asking: ”Why would one want to go faster?
    Regardless, I will answer it with true, but what some will perceive as silly answers:
    1) Onlookers sometimes scream and wave their arms requesting a "drive by". And yes, I can barely hear them at that distance even with the wind at their backs.
    2) I've rid my entire neighborhood of Canadian Geese with this boat and my neighbors are very, very thankful. There is however the occasional stubborn individual that will make me chase him/her to the ends of the earth before they will hop out or fly away.
    3) It’s highly annoying to have a run interrupted by a brief shut down when I occasionally overshoot my range.
    So, DO I HAVE A RANGE ISSUE? In my opinion, YES.
    Dec 2009
    on
    2,187
    Yep by that description I'd say you have issues! Not sure they're with range though!
    Great way to give boaters a bad rep with the greenies in your area by actively chasing wildlife!
    Jun 2011
    773
    Best bang for the buck, period. I will likely upgrade from my FlySky GT3B soon - for the better daylight vis and LIPO batt. But lack of range has not been an issue with my old GT3B TX or any of the $7 FlySky recievers. Santee Lakes lake #1 measures 1/4 mile long, and I have yet to have any reception problems.
    I got tired of crashing my 3D airplanes flown using Futaba FM so I quit that RC sport 5 years ago. Now with the excellent 2.4 G Hobby King HK 60F transmitter (FlySky relabled) & HK 60F 6 channel reciever in my shop, I may return to flying. For now I'll keep using it with my sailboats. Note: IMO the latest 2.4 G transmitters have made the seperation of air & surface TXs a moot point. That and the fact that the nearest flying field is over 2 miles away from my boat pond.
    But, if I'm imsinformed about the surface/air issue, please feel free to enlighten me. JIM
    JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
    Oct 2011
    OH
    184
    Quote Originally Posted by siberianhusky View Post
    Thanks for the laugh! Seriously.
    If you were educated on the Canadian Geese issues we've had in my area and the different methods professionally employed for geese abatement, you would know that the pros that are hired locally do use RC boats as it's one of the most effective/humane/efficient techniques.
    You could go so far as to infer from my message that I've heard nothing but praise and encouragement from neighbors, and our HOA. Relative to the crap they cause (literally) amongst other many other things; no one really cares about the yapping of the scarce "greenies". If there had been concerns, believe me, I would have already heard them as I’ve been doing this for years.
    Mar 2010
    MA
    3,573
    I also use flysky. Super affordable. I'll have to check out the c version
    Oct 2011
    OH
    184
    Seems like the overwhelming consensus is Flysky. Thanks guys!! I will give this a good look!
    Mar 2010
    MA
    3,573
    Yes. Make sure if you get one you set the fail safe as instructed! HobbypartZ has them at a great price. I love mine
    Dec 2009
    on
    2,187
    Life in the trailer park I guess.
    Oct 2011
    OH
    184
    Maybe ALSO, attempt to fire up a few more brain cells prior to typing? HOA = Home Owners ASSociation? Big house on a a big lake....what an off topic moron.
    May 2012
    282
    Anyone who does this, is , in my opinion, A Douchebag extraordinaire.
    Jun 2011
    773
    You guys Quack me up. JIM
    May 2012
    282
    Quote Originally Posted by JIM MARCUM View Post
    OMG, there's GOT to be some sort of penalty for that "Wise-quack".
    Oct 2011
    OH
    184
    HA! Jim.
    As for xland and husky: Did you both have cute lil baby Canadian geese as pets or something? I'm sure your opinion is highly respected but if you knew wtf you were talking about, you'd know there are many companies of "douchebags" which are employed in our area for this exact type of abatement.
    Thanks again to everyone who provided on topic help...I got what I needed.
    May 2012
    282
    HA! Jim.
    Thanks again .
    Hey no prob, that's what we're here for
    Dec 2009
    2,041
    I agree as well. I've used both the GT2 and GT3B for the last couple of years and had no issues with either. Here's a thread where someone has actually tested the distance at 2 miles. http://www.jrcbd.com/showthread.php?...l=1#post591128
    Oct 2011
    OH
    184
    Holy CRAP!!! That 2 miles sounds relatively legit + $39 for BOTH TX/RX + positve reviews in the high 90% range, damn!
    I just got the FS-GT3B even tho it almost sounds way too good to be true based on the prices of systems I've been looking at.
    U guys, minus a few off topic tree huggers, RULE.
    May 2012
    ID
    53
    Shoulda went the extra $20.00 and got the GT3C though. Easier to read screen and all around better built and feel to it. But at least you got a upgrade Like I posted earlier this mornin up inthe thread, Best deal for 60 bones!!!
    Race on bro!
    Thank you much!
    Hydropilot
