Results 1 to 11 of 11
Thread: servo barely moving
    Mar 2012
    MO
    17
    Angry servo barely moving
    Hey guys, my servo is barely moving. I have it plugged into the right channel too.. I even unplugged it and tried a different servo, but it still only moves a bit.. does anybody know what could possibly be causing this? & by the way I'm running a tactic ttx240 pistol grip with a tr324 receiver.. The esc is the stock blackjack esc..
    Thanks, Shane
    Blackjack 26 custom, Thundercat 31, Rustler vxl, scx 10 blazer(mudder/trailer truck)
    Aug 2010
    uk
    2,887
    Try turning the st-rate knob as this should alter the servo throw either left or right, the arrow should be in the centre to give even throw on the servo or set to either side to reduce throw.
    Mar 2012
    MO
    17
    Thanks, but I tried all of that last night... I even rebound it, and still the same results... The throttle is working fine.. I hate when little things happen like this!!!! I'm gonna try a traxxas 2.4..
    Oct 2008
    376
    Your RX get wet any time? Try a spare rx and or tx. Could be the actual steering module on teh TX or a bad rx.... Tough to say....
    Plug the steering servo into the throttle port on the receiver. If it works, then you have your culprit.
    Oct 2008
    376
    There you go.... it's 11 am and I'm still slow... (though it still could be the actual steering module in the TX, though unlikely)
    Mar 2012
    MO
    17
    Quote Originally Posted by sanyijr View Post
    Nope, its brand new.. only used it once on a nitro thundercat... It worked great with the reciever battery hooked up to it... The servo's turned all the way like they should. Now when I have it hooked up to the esc in the blackjack, it just barely moves.. it was my first run with it too so I was goin pretty slow... Nothing got wet..
    May 2012
    NE
    9
    Does the steering moving equally in each direction? I know it was said in an earlier post, but are you sure you cheecked the steering rate knob not the steering trim knob?
    Here are the directions from the manual.
    SYSTEM CHECK
    Turn on the Tx, then the Rx. Make sure all servos operate according to the
    movement of the Tx controls (refer to fi gure 4).
    Steering: Turn the steering
    wheel left and right. Make
    sure there are no obstructions
    with the steering servo’s
    movements, and the servo
    moves in the proper direction.
    If the steering wheel is turned
    to the right but the model turns
    left, reverse the position of the
    Steering Reversing switch.
    Steering rate: This dial adjusts
    the limits that the steering servo can travel on each side. Turning the dial will
    widen or narrow the steering end points. Adjusting this dial to your preference
    can help to customize control of steering in different applications.
    Mar 2012
    MO
    17
    Yup, i just did that, and the servo steers all the way !!! the only problem is, it steers with the throttle, not the wheel.... can i change this??? the servo was in *ch2* when i did this..
    Mar 2012
    MO
    17
    Quote Originally Posted by jwray View Post
    SYSTEM CHECK
    yes, but only about a half a centimeter... and yes, when I turn the trim it moves about half an inch, and when I turn the steering rate knob it moves a whole lot, but when i turn the wheel, it just barely moves
    May 2012
    NE
    9
    If you swapped the steering and throttle plugs and you got good throws out of the steering servo then I wonder if the rubber grip on your steering wheel is slipping or is the key on the steering knob stripped not letting the pot in the transmitter get full travel either way it sounds like the problem lies in the TX.
