Results 1 to 2 of 2
Thread: thrust bearing
    Dec 2011
    fl
    32
    Default thrust bearing
    I finished switching out my water lines,collet, flex cable, and bushing. Should my thrust bearing be locked up against the motor or should i have a little wiggle room. With my ul-1 the bearing sits flush with the motor but on my revolt and MC I have to add a spacer after the bearing and then it's super tight.
    Thanks, Eric
    Jul 2012
    480
    Quote Originally Posted by flyingjunky View Post
    Thanks, Eric
    What is the size of the spacer you installed? My trust bearing came with a .100 spacer but I have not installed it yet.
