Results 1 to 3 of 3
Thread: Mystic and battery match
    Sep 2010
    4
    Default Mystic and battery match
    Hi Guys,
    Im trying to figure out something. I have decided to get the Mystic 29. Next of course is battery selection. Luckily I think I can save some money because I have lipos already but want to know from some of you more seasoned boaters what your thoughts are.
    The lipos I have are Turnigy 30/40c 5000mah. 2s These are hardpack batteries.
    Can I use these and what type of speed and run time shall I expect?
    Cheers,
    John
    Apr 2011
    37
    You can use em, as long as the c rating and mah and # of cells are the same, it's also a plus if they are close in the # of cycles. Most FE guys prefer soft case lipos but those will work. You'll get about 34mph on the stock set up for maybe 5 minutes of run time.
    Sep 2010
    4
    Thanks!
