Results 1 to 5 of 5
Thread: Motor torque
    Apr 2011
    120
    Default Motor torque
    I hate that the outrunner motor makes the p1 twist so bad. Any way to stop that? Without getting another motor
    Apr 2011
    5,666
    Mine doesn't twist! Adjust your trim tabs, I bought mine used here and the previous owner installed his own, these are a lot better than the current trim tab/ turn fin combo. http://www.offshoreelectrics.com/pro...d=ros-spdt-150 and these: http://www.offshoreelectrics.com/pro...prod=ose-80060
    Apr 2011
    120
    Thanks. I'll try them
    Apr 2011
    5,666
    Mike, I am no expert in tuning a boat, but before you start, you should have an idea of the settings. On my trim tab I measure the distance between the blade and the bracket. Also i find it is useful to have a steel ruler.http://www.ebay.com/itm/Mascot-Preci...06%26rk%3D2%26 I place it ( on its edge) along the hull bottom and trim tabs, you can tell then what angle it is set. I find the tabs need to be either neutral or a bit "negative---pointing down). For the P1 my stinger is absolutely neutral and/or with even a hint of "positive" ---and that got rit of most of my unstabled manners. Hopefully someone who really knows will give you better advice.
    Good Luck and have fun.
    Sep 2010
    nj
    4,289
    Hey,
    What prop are you using and on what s cells for your setup ?
    And do you have any pictures of the setup in the boat with the cells and of your transom hardware ?
