Results 1 to 2 of 2
Thread: Revolt 2S-4S adapter ?
    Jul 2011
    93
    Default Revolt 2S-4S adapter ?
    I currently have 2S & 4S lipo's and was wondering this. Is there an adapter that will plug into the existing Revolt set-up (2-2S packs) that will allow you to run either the 2-2S or a single 4 pack ? I see in the manual you can do a bunch of soldering. I do not want to do this. I'd prefer just "plug n go" Any suggestions are appreciated.
    Thanks, Steve
    Jul 2012
    52
    Quote Originally Posted by madness67203 View Post
    the part in the manual with the deans plug jumper for the one side to run a 4s pack would be super easy to make. I would call your local hobby shop and see if they would make one up for you. one of these would work too. http://www3.towerhobbies.com/cgi-bin...?&I=LXPTT6&P=7
    This is the wrong part.. that is a parallel adapter, I dont think he is talking about running two 4s packs in parallel.
    Quote Originally Posted by sturco View Post
    Thanks, Steve
    You only need a single deans on 1 side that shorts the wires, then plug in your 4s pack on the other plug off the esc. The ESC see's 4s either way.
    Sorry No picture, but just solder a short wire or metal tab on a female deans plug that shorts the two posts.. (shrink wrap it) then plug it into one side of the esc. Plug in the 4s lipo on the other.
