I just bought the p1 and my second drive the esc blew up with in seconds. Couldn't believe it. Not hot just started driving. Runnin a 4s. And 640 prop. Why did it blow and is venoms customer service good?
Esc blew up
Tags: None
Did you buy new? I can only tell you my personal experience with them which was very good and pleasent! Many people here had negative experiences, and I think that dates to an earlier time. They have always returned my e-mail promptly and even followed up with phone calls. But it wat not for warranty work: I had to replace my motor in the P1 due to user error and they were out of stock at the time.
The ESC is the same as Seaking 60 amp. Should be fine on 4s with 40mm prop, although I ran x440 at the time. I now run X642 but with Seaking 120 a ESC. You may have a lemon and it is unfortunate, sorry to hear about that.Too many boats, not enough time... -
Yes it's brand new and ya I think I got a lemon. My brothers motley crew esc did the same thing. Aquacraft replaced it. I already orderd the 120a. Temps with the 642. Are fine?Comment
Yes! No problem, the motor is a bit warmer, but for out runners i am told it is fine. Hope you get the problem sorted out. If they replace a 60 amp ESC, you can save it for some other purpose, i think the 120 a is a good choice.
Cheers!Too many boats, not enough time...Comment
Did you get the esc wet? If so that might have caused it.Comment
If you plan to do prop changes and mods it would be in your best interest to buy a data logger or at least a watt meter. With boats you cant just swap props and not expect to have issues so its far better to learn what the power system is doing and know what to expect for loads and temps. Check out Eagle Tree Systems 150A data logger. The other guys I have introduced to this tool have loved it and made good choices based on the info they have studied from the data they collected. Its a must have tool for any electric RC tuning.VENOM RACING R&DComment
