wow, that's almost $250
oh yeah its in euros
might still get one though
"FE" STANDS FOR FRUSTRATING EXPLOSIONS
$92
awesome...who would of thought castle monster motors would appear to be wimpy in size comparatively?
Got the Sky RC Proteus X524 from Keith today. It's huge! Huge!!
Here compared to a Leopard 5692. Of course the Proteus is closer to the camera but still...
25" Arrowana with Etti 2970 3300kV. RCMK Flying Cat with twin HOR Outboards. 2 x SSS 4092 2140kV. Faluga 45" with Leo 56110 620 kv on 12s.
I use the same motor mount in my 40" mono. It is limited in cooler size unless modified.
The coolers on the 512 & 524 are too long for that mount.
Mello
Im waiting for mine too....would like you to give me some impressiona of it... i guess imnot the OnLy OnE expecting that...since most of us are looking forward to it...when do you expect to Test it??!??!
Best regards
Sent from my ASUS Transformer Pad TF300T using Xparent SkyBlue Tapatalk 2
Thats good to know. I use the http://southriverrcboats.com/ rail mounts in my monos. They are two piece, front and rear, and lets you build the way you want. I think the jacket will come off and be replaced by something that doesn't leak anyways. An o-ring change to something fatter will probably fix it.
@gerardobrando. If that question was for me - I wont test it until next spring. Too much on my table right now (boats, that is...). It will go into a 42" mono. I'll run it on 12s on a SeaKing 130A HV from Steve and try som gasser props. I think it'll spin a ~67 mm without a hickup
Znus,
Yours leaks? I tested a few of these to a decent pressure and they were fine...if yours is leaking I guess I will have to go through all of them. If there is a problem I will get it resolved.
Agreed Peter:
Kinda reminds me of an old song from the 50's (I think)...
Kaboom kaboom...shannna shannna, kaboom kaboom....shannna shannna Kaboom!
Grand River Marine Modellers
When the boss asks..
Yes, they are almost identical in diameter. The Proteus X524 is 56 (55,8) x 112.
@Keith. Yep, the seals (o-rings) doesn't fit very tight. Just speaking for myself - It doesn't matter and I'll fix it myself.
@Punisher & Doby. You're both experienced enought to know that when the kv goes down, volts go up (aiming for 25-30k rpm) the amps come down. If I draw 100A on 12s I still get some 4400 watts and get some headroom to 130A (180A burst). The reason why I'm so sure of this is because a friend runs a 40" cat with a 560kv 4962 Outrunner on 12S with a 80A HV esc with a 57 mm prop. His esc is 86 degrees Farenheit after the LVC hits, which means he can't be drawing more than 40-50 amps......and his cat is plowing through the waves. CG is way off. Maybe a 67 mm prop is a bit over the top but let us join up in this thread next may - june and see how it went
Well I am not going to claim to be an expert but here is my experience with 12c - I have a 57" Apache that uses a Lehner 3080/7 , 65mm prop and run in the 12T configuration the KV is about 490-RPM/V . Running a Eagletree for a few runs it shows the motor drawing 80amps continuous and 100amps peak....But......a Lehner 3080 is a much larger and a more efficient motor than a 5692 and will not labor quite as hard ( draw less amps ) as a 5692 with the same or similar KV turning the same prop . So you might be able to get away with a 130amp esc but it doesn't leave you a lot of room for error .
The stack & magnets are only 55mm long for the smaller 1280kv version. For same length of Lehner motor there would be a longer Field and magnets.
Nice motors. Are the 56mm Leopards 4 pole or 6 Pole like TP Power?
Ray, the Leo is 4-pole.
Has anybody ran one of these yet?
Time will tell - at around $90USD - I am wondering???
Around 1/2 the cost of the TP Power - and a max of 5280watts??
I think I will wait and see
Scott..
Ok, so I found this thread by googling the 524-3t after finding it on Keith Bradley's site as well as rc echo.com. My question to all of you experienced builders out there is "with a 54inch drambuie, would I need 1 or two of these? And on what battery setup?" I'm not looking for record speeds, or even a competitive race boat, I just want something to do with my brother, that's fast and worth it. And I've been told by many I should have gone with a deep v but it was on Craig's list for a steal. Sorry if I'm off topic here but there's not much out there about these motors. And yes to all I'm a newbie to marine rc.
The next big bad boy from trackstar
53.5mm x 114mm
http://www.hobbyking.com/hobbyking/s...tor_760KV.html
Hello Guys
Mine X524 motor have arrived yesterday..First thing i did whas to open for seeing it inside...
Here follows some pics.. :
Waiting for inputs!
The finish seems better on the sky rc motor compared to TP5850, bearings are from NSK, the shaft is correctly grounded...
The water coolet seems to loose.
Altough, from appearance TP 5850 seems to handle a lot better bigger amps, due to higher content of cooper compared to Sky rc!
Best Regards
I like show & tell.
Looks identicle to the inside of my HK Version.
Thanks for sharing!
The one thing not so hot is how the rear connectors are pressed into the endbell.
I tried an 8mm connector I had kicking around (cheapo ones) and they were so tight I almost pulled the whole connector out with the female and white nylon/ptfe sleeve! They are soldered well inside so, hopefully its not buggered.
The 8mm it comes with are not as tight and may not do that as bad...
I bet that Trackstar motor will take 10s no problem..
Dang Hobbyking! Causing me to spend more money now to do a brushless conversion for my Baja 5b
That motor on 6s would be plenty, 8s and holly crud!
http://www.youtube.com/watch?v=GfMTStJsvs8
This is a video that HK did on this motor!
Details
Code IM679
Packet Weight 1474.00 grams
Price: $111.90
Quantity Price
*Note:
Introduction
Proteus Series Motors are designed for large scale rc boat (1.5-2m length).
The revolutionary design of Proteus motors is its unique wire configuration. There are six connectors on the motor and the user can switch the wire configuration (wire or triangle) by themselves at any time. When the user requests the motor with more RPM and high speed, he could use triangle configuration; when the user request the motor with more torque and power, he could use star configuration,. In this case, one piece of motor can meet the user’s request for speed or power in different situation.
What’s more, there is water cooling shell outside of the motor. It is designed to cool down the motor temperature so that the motor could perform best.
These motors can be switched between STAR and TRIANGLE with configuration.
There are 6 connectors on the motor.
Triangle Configuration=More RPM
Star Configuration=More Torque
Specifications
X524 2Y System
Watts: 6300W
Max Voltage: 33V
Max Amps: 190A
Resistance: 0.0069
KV (RPM/volt): 910
Max RPM: 30000
Length: 112mm
Diameter (w/fins): 55.8mm
Weight: 1035g
Shaft Diameter: 8mm
Length of extend shaft: 30mm
X524 2D System
Watts: 6300W
Max Voltage: 19V
Max Amps: 331A
Resistance: 0.0029
KV (RPM/volt): 1580
Max RPM: 30000
Length: 112mm
Weight: 1035g
Shaft Diameter: 8mm
Features
High Quality Bearings
Rotor - 4 Pole Neodymium Magnets
Stator - Super Thin(0.2mm) Laminations
Super Strength 8mm Shaft
With Water Cooling Shell
6 Connectors
2 Wire Configuration-Triangle & Star
