I ran mine today and I think it got a little wet. It's now blinking a red light 3 times. Is that whats wrong with it? Or maybe my motor? Thanks for any help
I would bet its a receiver problem.
white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
Thanks.. I'll try a different one and see what happens
I don't think its the receiver as it seems to be working fine with the steering servo... Hoping someone here has had experience with a wet T180?
Is this the same as Seaking 180A? if yes, I had one submerged for 30 min. and was ok, they are supposed to have been sealed. But you never know. If I were you I will wait a day or two then try again. Also check for corrosion, after that the contacts were all green ( the lead that goes to the Receiver, the lipo plugs, etc., ) At the time I was using good Thunder Power lipo, I called the factory and the tech guy said it is typical for Lipo to have immediate corrosion and anything that is connected with the lipo at the time of water sudmerging, he said to just use a stiff brush or some object to scrape away the corrosion. I waited a month to try the lipo, waited until no trace of moisture was present, but the ESC was ok ( looked inside the plastic case and couldn't see any trace of water).
You can speed the drying up thing by dipping it in a bowl of rubbing alcohol. The higher the % of alcohol the better. Blow it out LIGHTLY with compressed air and let it dry thouroghly for a few days. T-180s are one of the toughest ESCs made & are hard to kill. A little spray-on sealant on the circuit boards (after it's dry) will help in case of any future dunkings. JIM
JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
Hi just an update, I dipped it in 90% alcohol and let it sit for a week, still no luck. I went ahead and picked up another T180, and I'm wondering do any of you spray Liquid Tape on the outside of the ESC? Where there are exposed wires and contact points? I was thinking about trying some on the new ESC but thought I would ask first. Thanks
Well I went ahead and sprayed all of the contact points with the liquid tape stuff, hopefully this will help some more with waterproofing the ESC
Pull the case off, give all components a thourough scrub with toothbrush and contact cleaner. Reasemble.. Drill a small hole in plastic cover and pump in liquid electrical tape...WATER PROOF
Do it to all mine, never had fail..
That sounds great Tiny! Thanks for the help. I'll do this as well
Where and when did you buy it? If from Hobbyking they will warranty it.
I bought it from a forum member but it was brand new. It still looks great, and to me it looks like nothing got wet. I still can't figure out why it doesn't work anymore.
I don't think you can go wrong sealing the thing up with spray tape... I do the same thing with my "waterproof" proboat escs...
Cheap insurance.
Chief
From the manual
After power on, motor does not work, such an alert tone is emitted:
“beep-, beep-, beep- ”(Every “beep-” has a time interval of about 2 seconds)
Throttle signal is irregular
Rudder channel may work, throttle channel may be bad. Does the throttle channel work with another ESC?
Yep the rudder works fine, and it doesn't emit any beeps. Just red light blinks one at a time.
I think when I first hooked my T180 up and tried to calibrate it, I had the same "no beep" and flashing light thing as you described. Turned out I had to put my throttle channel on the TX to "REV" instead of normal.
I also have a T-180 that thinks its a turnsignal and blinks with no beeps and no throttle response .....steering channel works fine. Does anybody else have any more tips out there? Im sure there are some FE addicts out there who have lots of experience with this esc and have fried hundreds! lol....then sob.
