Diesel are you suggesting a 2s and a 3s in series?
Prepping for some runs later today...
My BJ29 at full throttle yesterday. Awesome pic by my wife!
What is the best method to remove the flex shaft for re-grease without removing the whole strut?
Use 2 wrenches to loosen the flex collet at the motor and the shaft slides out from the strut. Who told you you have to remove the strut? Take prop off first and nut. Should be no problem.
Nice pic Lomdel ! How many S? And was that the stock prop. Also what do you think about the turning with the offset rudder.
Nothing stock about that BJ29. OSE upgrade Leopard motor and T180 ESC on 6S with Octura prop. Stock driveline parts, though. About 45mph I think... She turns on a dime!
you don't need to run 6s for speeds in the 50s..stock speedo ul 1 motor x642 prop 2x 2s 5500mah 50c with no timing..for shorter runs I can crank timing up to 7degrees gps at 56mpg
Revolt 30, River Jet, Southampton Tug, Outcast 6S BLX, 8ight-E, Ten-SCBE, 22 2.0.
'09 Miata.
Ibanez basses and guitars. Mapex drums, Zildjian cymbals.
Ready to roll!
