Those are fine. Higher the C the better.
The PB1800 doesn't have the torque of the PB1500 and this Hull doesn't like a lot of pitch so.
- Grim 40x52/3 or x440/3
- Grim 42x55
- x440
- prather 215
- x442
Some folks will say the x642, I didn't care for that Hull with that prop. Remember this is the same Hull as the mystic and mg.
Not sure how well the PB1800 will swing a m445, would be a nice prop for the hull. Just check temps often, a prather 220 same thing, check temps. ...
CF40, 42 and 45 will all work well also. Not as efficient as a metal prop, but cheap upgrades. The stock PB prop isn't that bad either, just sharpen and balance it. Its around the same specs as a prather 215 (if they're using the same stock prop they used in the past)
S3 iPhone killer via Tapatalk
